debadge help!!!
Old Sep 19, 2008 | 03:25 PM
BIGBOOMER77's Avatar
Socal
debadge help!!!
ok so i debadged my cl but theres this hard crusty outline where the letters use to be... wd-40 doesnt seem to be working.... about 90% of the glue is gone but there is that stupid outline.... u cant really notice it ur not looking for it but its there especially if thelight hits it just right...... any ideas? anyone else have the same problem?
Old Sep 19, 2008 | 03:31 PM
gnuts's Avatar
3.5 psi
There is a thread on this somewhere. There's a product called Goo Gone. Don't know where u would get that in CA tho. I also remember that a few coats of wax helped to blend things in after all the glue was gone.
Old Sep 19, 2008 | 03:45 PM
Socal
anyone know where to buy goo gone in cali? other then online that is...
Old Sep 19, 2008 | 03:47 PM
disgruntlednut's Avatar
01 Type-S, Sexy Silver
I used Goof-off... Any strong adhesive remover or paint thinner should be able to take care of it... Then some polish to the area to even things out.
Old Sep 19, 2008 | 03:54 PM
Socal
would a paint thinner be safe? why not just put some MEK (methyl ethyl keytone) lol jk i accidentally spilled some on my kitchen floor and now theres this white bubbled up spot in the corner of the kithen lol
Old Sep 19, 2008 | 03:55 PM
brianlin87's Avatar
ASM I.S. Design FTW.
goo gone can be purchased at target.
Old Sep 19, 2008 | 04:24 PM
Dan's Avatar
Dan
Confused
WalMart
Old Sep 19, 2008 | 04:47 PM
acetone will work too.
Old Sep 19, 2008 | 05:04 PM
Type S of Edmond's Avatar
2001 CL-S
This happend to me, I debaged mine months ago, its still there but it is hard to see unless you look for it. idk whats up with it, its not glue. I even wet sanded it a little and all it did was smoth it out but looks the same.
Old Sep 19, 2008 | 05:09 PM
CL-Slick's Avatar
Chillin' in my trailer
They make an automotive goo-gone formula. I've used it on my car before. It works great.
Old Sep 19, 2008 | 06:45 PM
nspec_ya4's Avatar
Regional Coordinator (Texas)
+1. exact same. it'll be repainted any ways, but just for to learn. i'll try different things soon.
Old Sep 19, 2008 | 08:53 PM
Garkon's Avatar
If there is still glue on the trunk, here is what i recomend, it's what i did, worked for me. Depending on how much sun your car has had you may see a slight difference in paint shade, but it should blend with a good few weeks of warm sun.
1. Wash the area well with car soap, a little more concentrated than you would use if just washing the car. Keep the bucket for later.
2. Dry off the area around where you'll be working.
3. I personaly used some 99% alcohol to get my glue off, goof off or some similar will work, never used it so don't know if it works better or not. Use some cotton balls, get them pretty wet w/ the alcohol, and start going to town. I took my time, used a lot of cotton balls and elbow grease(when one starts collecting gunk, use a new one). I used about 15 cotton balls for the 3.2 Cl and ACURA badges. When i was done i was left with a perfectly smooth surface, no outline.
4. Wash the trunk again like you would if you were washing the car. (i personally took this time to wash my entire car,, why not)
5. Dry well.
6. Use a paint polish on the areas you worked on. Then follow it w/ 2 coats of wax.(or one, whatever you feel like).
7.De badge done!
If their is an outline after nine months, then it's just little mars in the paint, probably from all the years of gunk building up in there. Who knows how dirty that cars trunk could have been under the care of the previous owner. If there SUPER bad, hey, at least you have an outline already in place to put em back on. Or just paint the trunk.
edit: BTW, i'd go w/ no fuckin way on the MEK, .
Old Sep 19, 2008 | 10:13 PM
Ralphie917's Avatar
also used a bit of adhesive remover (goo gone) and finished whatever dirt was left with an extremely light polish (beleive i used megs swirl remover and an orange pad) -- followed by a coat of wax
Paint looked new, and no remnant of any dirt whatsoever
TLDude876
Dec 28, 2016 03:18 PM
jmaxima03
Sep 27, 2015 10:22 AM
HOWELLiNC
3G TL Photograph Gallery
Sep 17, 2015 10:04 PM
buhhbuhh
Jul 27, 2007 09:58 AM
