CT Sways on.. will drop help handleing even more?
Manny Tranny
Expected to have both CT Springs and Sways on at once. Ended up with CT Sways on with Stock Springs. Handling has improved two fold around those corners!
Has anyone ever done Sways first, then Springs? Will I feel an incremental suspension performance with the drop?
Definitely, I had sways on my '01 CL-S without springs for some time and then moved them to the '03 CL-S6. I went this way for almost a year before the springs recently went on. And yes, there was a marked difference in handling with the addition of the springs.
Manny Tranny
Manny Tranny
Originally posted by DeansblackCLS
stejus,
I just did the reverse of that.....springs, then sways....and there is definately a difference in the way the car handles with both.
I know you will be happy!
stejus,
Re: CT Sways on.. will drop help handleing even more?
Now my 03 is stock...until I replaced the sway bars. The weight of the car is alot lighter feeling than the 01 with CTsprings/sways. Unfortunately, the car still has alot of body roll and the sways DO WORK..but it's not that different from stock....I know that if I lower the 03, shit, it will be freakin' AWESOME.
That is my experiences with springs/sways. Also, I find the car a bit bumpier/bouncier (due to stock struts) but other than that, I would not say the car is unbearable when driving with both springs/sways....with just the sway swap, it feels EXACTLY STOCK.
Black is a ***** to Clean
1 Post
I'm probably gettin Teins & Sways installed this week! I can't wait!
Do you guys recommend against getting both installed same day? I assume it would be a cheaper install but you would not be able to pick out what benefited what in the handling as opposed to seperate installs.
MrHeeltoe
20
02-23-2023 01:54 PM
MrHeeltoe
09-29-2015 10:43 PM
MrHeeltoe
09-28-2015 05:43 PM
