Crankcase overfill
4th Gear
Crankcase overfill
I recently had my oil changed at an Acura dealer in St. Louis, they overfilled the engine oil by 3.5 quarts. Drove it 541 miles before I identified the problem and had it dropped and refilled at the correct level.
What if any problems can I expect? No valve cover leaks yet.
Jim
Jim
From my own experience:
- spark plugs fouled out, dark and covered with oil when I extracted them
- hard starting problem, caused by fouled out spark plugs
- oil inside the spark plug chambers
- oil inside the intake and throttle body, caused by oil blow-bys entering the combustion chambers, into the PCV path, then into the intake path.
dealer overfilled oil by 3.5qt, that's unheard of!!!
Gimmie my points Biatch!
Re: Crankcase overfill
Jim
Jim
Get this documented. I would call the regional rep. and get it in writing that if anything happens to the engine due to this fuck up, Acura pays.
I'd be pissed as hell, too.
4th Gear
The oil change was in St. Louis while stopping over during a trip. 541 miles later I had it filled properly in Tulsa. It is well documented. No apparent damage yet. Still got our normal trip MPG of 30.7
get this documented by the reg rep,,,, if anything ever goes wrong with your engine,,, they will give you a new one,,, but you have to have the documention,,,
i would call the and write to the regional rep... so when you need the lawyer.
Some overfill is not too uncommon.. check your dipstick after oil change... make the dealer do it over.
6MTUA5
719
05-23-2014 10:28 PM
FN P90
06-02-2007 06:13 PM
