Coolant Temp guage Help!
Old 11-04-2007, 12:01 AM
OG 3.x^7 rawr
SPoolinspOON's Avatar
so this has been like this for a little bit and I'm not sure what to check. The gauge seems for the coolant seems like its off. When the car is off, it sits 1cm above Cold. When the car gets hot, it goes a bit below half way which I guess is right. Now what could be bad? Coolant Temp sensor? Sender? How do I go about checking/replacing whatever is bad? Thanks in advance!
Eddie
Old 11-04-2007, 12:07 AM
sinfulj32's Avatar
i still dont get whats wrong. if your water temp is a little below half, than it sounds normal to me.
Old 11-04-2007, 01:31 AM
Moderator Alumnus
BigLizard's Avatar
Normal...I wouldn't worry about it too much. If you want to be self conscience just change the fluid. Easiest way to change it is to unplug the either one of the hoses going in or going out of the radiator while the motor is running. Just make sure not to over heat the engine though! Then refill...plug the hose back in obviously, run the engine when its cold and fill it through the top of the radiator.
If you have the Mugen cooling mods and if you live in a colder area...you'll notice during the cold months that the t-stat will be lower than normal.
Old 11-04-2007, 04:28 PM
OG 3.x^7 rawr
damn, I must of been mad tired when I posted. I ment to say when the car is off. The coolant is like this....
Old 11-04-2007, 08:09 PM
fsttyms1's Avatar
Received 3,063 Likes on 2,119 Posts
sounds like the gauge is off
Old 11-04-2007, 08:22 PM
fuzzy02CLS's Avatar
It's an idiot gauge anyway. If it looks normal when the car is hot, you should be fine.
Old 11-05-2007, 06:02 AM
OG 3.x^7 rawr
so would that mean I need a new gauge if it doesn't work all the time?
CL-S progression 01
01-26-2016 04:15 PM
ROSSARONIE
10-02-2015 11:46 AM
Jboat
09-30-2015 10:58 AM
Username 0
2G TSX Performance Parts & Modifications
23
09-28-2015 09:09 AM
Ratheruneeq
09-28-2015 07:41 AM
Quick Reply: Coolant Temp guage Help!
