Coolant question
Old Feb 9, 2012 | 03:25 PM
Jmoney6's Avatar
Coolant question
Can I use dex-cool in my cl-s? I think $25 a gallon for honda coolant is a little much. If not dexcool is there another non honda fluid I can use?
Old Feb 9, 2012 | 03:28 PM
you can use anything that is PHOSPHATE AND SILICATE FREE.
Old Feb 9, 2012 | 03:32 PM
civicdrivr's Avatar
Peak 50/50?
Old Feb 10, 2012 | 01:30 PM
dfv3.2CL-S's Avatar
Anything Phosphate and Silicate Free.
Old Feb 10, 2012 | 11:05 PM
CL-S progression 01's Avatar
lowrd on tein CS biatch
i used the prestone silver dex-cool coolant on my car... running like a champ.
Old Jun 21, 2012 | 09:17 AM
JBONN's Avatar
Vegas Bum
I used Zerex's Dex-cool 5 yr 260,000km Antifreeze for $16/GAL, so far so good, the only potential problems I have heard is that you need to make sure it stays topped up.
http://www.valvoline.com/products/br.../antifreeze/41
Old Jun 21, 2012 | 02:10 PM
dfv3.2CL-S's Avatar
I am not sure why you would have to be topping off because of using Zerex. This is a closed system. If you are topping off coolant fluids in you radiator you most likely have some sort of a leak. I know that you have evaporation but that would be from your overflow bottle only. And if that is the case then any brand of fluid would need to be top off regardless of Honda, Preston or Peak. Just make sure it phosphate and silicate free.
navtool.com
3G MDX (2014-2020)
32
Jan 20, 2016 11:43 AM
navtool.com
31
Nov 16, 2015 08:30 PM
LeVeL
Oct 18, 2015 04:19 PM
ROSSARONIE
Oct 2, 2015 11:46 AM
Username 0
2G TSX Performance Parts & Modifications
23
Sep 28, 2015 09:09 AM
