coolant flush @ what mileage??
///M POWER
1 Post
when i went in for an oil change yesterday the tech told me i will need a coolant flush and that most people do it @ 30k, you guys think its too early with 36k miles on my car. the dealer charges $95, how does that compare to your dealer?
db
db
i have 13K.. but the car is 2+ years old.. so it will be getting changed when I install the intercooler...since I bought a case of honda pre-mix... ![Wink](https://acurazine.com/forums/images/smilies/wink.gif)
D, you know they make coolant testers.. relatively cheap... .. open up the rad cap (when the car is NOT HOT) and dip the tester in... read the chart and see if you coolant gets
or
okay pumkin?
![Thumbs Down](https://acurazine.com/forums/images/smilies/thumbsdown.gif)
okay pumkin?
My manual says 3 yrs or 45,000 miles for coolant. It also says 3 years or 45,000 miles on the brake fluid. I think each cost about $50.00 at Acura of Memphis who has a good service department btw. .
Boomer SOONER
I thought coolent would last WAY longer than what you guys are saying...pretty much 100k+. Because of the quality of coolent and the aluminum radiators - it is very hard for rust or other build up to occur in modern radiators, and that is what you are trying to avoid when you flush your radiator
but with that being said, it is very easy to do it yourself - I dont understand why people go to the dealers for such easy maintenance like this or getting your oil changed?
Originally Posted by Louie11
I forgot if you have had a trans swap they also change the coolant at that time. since they have to drain it. So you get a freebee.
Originally Posted by Technique
That's VERY good to know! Can someone else confirm this 100%?
Username 0
2G TSX Performance Parts & Modifications
23
09-28-2015 09:09 AM
