Constat rev????
Old Jan 1, 2008 | 05:31 PM
VIPCLS's Avatar
P.
Constat rev????
I just got back into town from the holiday break, and I get into my CLS and let it warm up, and about 1 to 2 min into warming up the vehicle automatically keeps reving to 2000 rpm then back to 1000 rpms,and the check engine light is on??? What the hell is goin on!! I have a appointment to take the vehicle in thurs. Has anyone on here had this issue, and is there a easy fix or does it need to be taken in to a mechanic. What a good way to start 08!!
Old Jan 1, 2008 | 05:38 PM
Dirty Type-S's Avatar
B A N N E D
maf sensor..?
can u rev it by urself? or when u rev it it does nothing?
Old Jan 1, 2008 | 05:39 PM
visuelz's Avatar
East Coast Crew
Throttle body sticking? Bad idling machine or whatever they call it...lol
Old Jan 1, 2008 | 05:42 PM
VIPCLS's Avatar
P.
Originally Posted by Dirty Type-S
maf sensor..?
Yea I can rev it by myself, but it automatically keeps reving when I have it in park to 2000rpms, and when I am in D5? What is the maf sensor, and is it expensive to fix?
Old Jan 1, 2008 | 06:46 PM
ChucksCL-S's Avatar
Most likely a bad idle air control valve, fairly common. It's at the throttle body (underneath it if I remember right) and can be removed and cleaned i think. BTW my code said TPS bad Throttle position Sensor, but my tech said no its the IAC valve, he was right. Bad IAC can throw a TPS code on a scan tool. It is not a hard job.
Old Jan 1, 2008 | 06:58 PM
VIPCLS's Avatar
P.
Well I hope that it is just a simple fix like that, should I let a tech fix the problem? Appreciate the info.
Old Jan 1, 2008 | 07:05 PM
TCM 01 CL-S's Avatar
Uses turn signals in my
What he said^. It can be cleaned.
BTW, the CL doesn't have a MAF.
Old Jan 1, 2008 | 07:17 PM
VIPCLS's Avatar
P.
Well some good news, but I think I am gonna let a professional deal with this situation. Also when I had to drive the vehicle, I get up to speed to say about 50 and the speed limit is 45,and I have to let off the throttle, it has a sudden jerk!! At first I thought it was the tranny about to go again! I will fill you guys in on the results after I get the problem resolved.
Old Jan 3, 2008 | 01:51 PM
VIPCLS's Avatar
P.
My friends, two bad sensors was the verdict. Its in the shop right now,also getting the front brakes replaced, will get back in the next couple of days, and will be back on the road again!! What a way to start the new year off
Old Jan 3, 2008 | 04:47 PM
nbennettksu's Avatar
i heart latin chicks
Old Jan 8, 2008 | 07:48 AM
C The "S"'s Avatar
Which sensors? I'm having exactly the same problem as you are. Any info would be much appreciated!
Old Jan 8, 2008 | 02:06 PM
fsttyms1's Avatar
If your having issues with the rpm jumping up and down most likely its just the IAC. Clean the IAC valve and put it back on. and see if the problem goes away. It takes less than 30 min to do.
Old Jan 10, 2008 | 11:05 PM
VIPCLS's Avatar
P.
Ok, I went out to my car and got my paperwork for the service that I had done. The paperwork states that it was a a faulty IAC valve, and map sensor,and clear codes. In my opinion I would take your vehicle to a certified mechanic and have them repair this problem professionaly, you cant just clean the IAC valve, and waaaa laaa the problem is fixed. It was a pretty expensive repair for these two parts, because they coeinsided with each other, so both will need to be replaced if you are having the same frustrating problem. Hope this helps!!
cycdaniel
Dec 17, 2019 10:58 AM
DerrickW
Nov 15, 2015 05:52 PM
Sep 14, 2015 03:16 PM
phillyguerrilla
Sep 11, 2015 06:39 PM
ninersfgiantsfan
Sep 9, 2015 01:14 PM
