Comptech Supercharger
I found a comptech supercharger that is on an 02 acura tls. Supposedly has 10k miles on it. I am thinking of picking it up for my 03 acura cold 6 speed and wanted to know what I would need to do for it to fit on my car.
Also, would coilovers from the same car fit on my car
Look at post #3 on the thread below for the CT-E CLS6 S/C'er checklist for what you should attempt to get from the similar kit for the automatic TL, at least it's a start.
https://acurazine.com/forums/second-...roject-966540/
Good Luck!
bluedc2 (02-16-2019)
Thanks. It appears I would need a different elbow since I have 6 speed, and the esm would need to be changed due to voltage.
I had found an 03 acura cls supercharger, but same issue as its an auto. Anyone know where to get a different elbow since comptech is going through a ownership change and not making any more parts for the acura cl.
Small chance you'll be able to find it in the market here but you'll likely have to wait quite a while for such an item to appear. Generally they're kept as part of a package with the supercharger because they're so scarce. It's incredibly unlikely someone will be willing to part with just the elbow as it makes their supercharger a far harder sale (if not nearly impossible) without it.
The Second set of picture(s) below show a CT-E S/C'er kit for the manual 6-speed transmission CL-S.
Just curious, what 'different elbow(s)' would be needed from the 6-speed manual kit to make an automatic kit compatible for a 6-speed application???
Automatic S/C'er kit:
Manual Transmission S/C'er kit:
Are you talking about the 'inlet manifold' that connects to the S/C'er impeller housing on one end and connects the throttle body at the other??
OR
Are you talking about the secondary 'outlet elbow' (the one that has a place for the MAP sensor) that connects to the actual intake manifold on the engine??
In short, which of the depicted elbow(s) above (in any set of pictures) are needed for the 6-speed??
I have a 6-speed kit and the only 'elbow' differences I really notice are at the throttle body end of the automatic kit.
The 6speeds used a different elbow that attaches to the manifold.
"The CL-S Auto kit will work on the 6 speed as well.
The main differences are the ACM voltage setting and the lack of TCS on the 6 speed (just don’t install that elbow)."
The CLS6 ACM voltage (2.93v) setting is easy enough to adjust. Refer to the attachment below.
Now you can go get that Auto CL-S kit??
If you really want to do it 'right' forget about the 'ECM' and get the standalone on the link below:
AEM EMS Acura CL Type S 01-03
Greddy E-manage ( I got a couple of em) or AEM FIC 6 (preferred) would work. If you use the FIC-6, tune it in o2 Skewed mode.
However, for the 'layman' that owns a CLS6, do you readily know of a source that has a 'plug n play' harness that allows for all the cars functionality like the Dezod harness??
GK83
04-24-2016 01:22 PM
100degrees
05-15-2011 07:47 PM
k2boy22
07-10-2010 01:49 PM
Nashua_Night_Hawk
05-31-2004 11:08 PM
