Comptech Flywheel/Clutch Install help/question. Car Stalling After braking.
Old Oct 25, 2009 | 03:56 PM
heyitsvu's Avatar
OM NOM NOM NOM
I had in a posting that my transmission was beginning to feel spongy. Had it checked out and turned out that the clutch plate was dying and needed a replacement. I had pieced together the comptech flywheel/clutch from ThinJim and KrisDLM a year back and was getting it installed. I had my mechanic who did the 6-speed swap for me do the clutch and flywheel for me and he ran into some problems.
After everything was correctly installed, and he turned on the engine, once he stepped on the clutch, put it into gear, he was able to drive it, change gears and everything, but once it came to a complete stop, the car would stall, even with his foot all the way down on the clutch. If he starts it up again, puts it into gear, and goes, it would go again. It seems like the pressure plate is not releasing the pressure on the cluch. Does anyone know as to why this might be happening? Could it possibly be a sensor that may be out?
also If you compare the two flywheels side by side, the comptech flywheel is missing 3 rounded out corners that accommodate for the stock pressure plate. Could this possibly be an issue?
Picture is @
Please let me know of any thoughts you might have on this.
Old Oct 26, 2009 | 11:30 AM
heyitsvu's Avatar
OM NOM NOM NOM
anyone?
Old Oct 26, 2009 | 12:12 PM
civicdrivr's Avatar
There is a sensor on the tranny (which I cant seem to remember its name). Make sure thats connected properly.
Old Oct 26, 2009 | 09:06 PM
Allout's Avatar
Blown is Best
You might want to reset the ECU. The motor revs down faster with the flywheel and it may need to compensate for the reduced revs.
I have not had that issue with my CT flywheel.
Old Oct 27, 2009 | 12:25 AM
heyitsvu's Avatar
OM NOM NOM NOM
Would that sensor throw a code if it wasn't connected? He had the car running, and no engine codes were thrown. He said he was sure that all sensors were connected as well.
heyitsvu's Avatar
OM NOM NOM NOM
Allout- The battery was removed in order to do the installation. They pulled the whole engine out in order to make the job easier.
Old Oct 27, 2009 | 01:11 AM
Accord_V6_400m's Avatar
4drs just wanna have fun!
Yeah, reset for the faster rev dropping flywheel
Mine kinda does that from time to time if I have the A/C on, but no flywheel just crank pulley.
The secondary crank sensor should be plugged in and im pretty sure it would throw a light and might even keep you rev limited to 2K.
Old Oct 28, 2009 | 02:52 AM
heyitsvu's Avatar
OM NOM NOM NOM
Hey everyone. Thanks for the responses. My Mechanic ordered a new clutch and pressure plate to do a comparison, and turns out it was the pressure plate. Reinstalled it and car runs like a dream. Can't wait to go pick it up this weekend.
Old Oct 28, 2009 | 09:10 AM
phee's Avatar
I got the Shifts
Send ur old flywheel to heeltoe. He needs o e
Old Oct 28, 2009 | 08:15 PM
Allout's Avatar
Blown is Best
Nice
Don't you love the way it drives? Much easier to control the rev's on shifts.
Old Oct 28, 2009 | 09:02 PM
fsttyms1's Avatar
I need a light weight flywheel.
Old Oct 29, 2009 | 02:12 AM
heyitsvu's Avatar
OM NOM NOM NOM
Originally Posted by Allout
Nice
Havent taken it home yet. I will see my baby this weekend. cant wait! I'll let you know how it feels to be driving with the CT setup
Feb 25, 2020 09:57 AM
james357
Feb 13, 2016 02:37 PM
NSolace
Sep 3, 2015 08:02 PM
Username 0
2G TSX Performance Parts & Modifications
Sep 1, 2015 09:37 PM
