Comptech Flywheel... clutch BROKEN!!
Guys.
I took the transmission off today and have finally figured out exactly what has happened.
The stock flywheel is a dual-mass unit. In fact, the face (which the clutch disc touches) is spring-loaded to flex axially a certain amount independant to the crankshaft. There is a very good reason for this... I have learned the hard way.
Basically, there were 'chunks' of metal inside my transmission. The Comptech flywheel itself (dimensions, clearance etc.) was NOT the problem. However, because the flwheel is a single-unit, the pressure-plate cracked. By this, some of the metal pieces that is used to release the clutch snapped. This has gotten caught inside the tranny and the flywheel and subsequently damaged the CPS (and shroud) and other internal parts. The clutch and pressure-plate ($340) is not readily available. I will NOT put the broken pressure-plate onto the car as if more parts come loose, the damage will occur again and might be worse. The transmission is still usable.
So, the verdict is that while Comptech's craftsmanship and customer-service (at least so far) have been great, this design has a very huge flaw - it cannot support the torque this motor generates nor is it a robust alternative to the factory design. I have NOT tracked the car... imagine if I launched this on slicks!
Subsequently, I cannot recommend this product, because its a matter of time before something pops loose on the pressure-plate and starts creating a mess inside the transmission housing.
The reason that last night the car did not run is becuase the Comptech flywheel is damaged and not usable.
I will be contacting Comptech reagarding all this. I do not want their product any longer and could accept nothing less than a complete refund. In addition, I hope they compensate me for my new clutch/pressure-plate (which is on order) and the associated labor-cost. I am not doing this last install myself.
I am attaching a picture of the pressure-plate... you can see the damage.
http://f1.pg.photos.yahoo.com/bc/gun...c=ph%26.view=t
If Comptech gives me a hard-time about this, I would appreciate any and all support this forum can give me.
I suggest those that are considering this product... NOT to purchase it. I also recommend those who have already installed the flywheel to remove it... or NEVER do a hard-shift through the life of the car!
sux that this had to be figured out the hard way by a customer of comptech. They should have done more R&D and made sure everything was right. Hope everything works out for you.
SHIFT_over.so.I.can.see
hope it al works out for you man. That really sucks... I know everyone on the board respects that your work is always top notch. You've definitely got our support if Comptech made a fault product. Hope it all gets worked out soon and they replace everything.
I wonder who tested it before you? Their R&D car must have had similarl problems either that or the production model just came out incorrectly.
I don't think they drive the Comptech S/C'd CL-S hard - it ran a 14.4 remember!!
It's just unfortunate because this design does not qualify as a reasonable replacement for the stock flywheel - that's just the bottom line.
I think I know what Comptech is going to say. "Transferring the springs to the clutch disc from the flywheel accomplishes the same thing". It does... but not to the extent required, in my opinion.
I did some research on single-mass flywheel replacements to dual-mass flywheels. There are many more springs on the clutch-disc for vibration and to soak up some torque and the pressure-plate design is changed appropriately.
The engine stalled during a hard 1-2 shift... so it makes more sense to me that the metal piece cracked and caused all that damage immediateley.
Where is my super sauce?
That's what my face looked like as I read your post.
Hopefully, Comptech will take care of you, not only for what you deserve, but for beta testing their product before a full release (they still do not have it listed on their site).
I hope they contact other people that have installed this product too, hopefully to prevent a problem.
Based on personal experience, I've been very happy with Comptech customer service. I hope they really take care of you in this time of need.
Originally posted by Zootking
I hope TypeS1967 reads this post...didnt he just install this on his car??
Hmmm sorry for all the mess your going through Allmotor... it must really suck, but thanks for the heads up..
Smitty
Could a similar result come from the inner bolts and parts of the transmission not being torqued correctly ? Just wondering if there was another way a tranny could blow up from replacing stuff is all.
Not Fast Enough
sorry to hear that it messed up your car, I would have thought comptech would have done a lot more testing to assure this crap would not happed I was really considering this, but now i don't know if i will consider comptech at all if they don't make it right with you!!!! by paying for the damage and refunding!
Kevin
Kevin
Spectacular Aroma About
Holy Crap!! That sux bad! So the clutch disc did have springs on it I take it? Solid disc/solid flywheel would be disasterous. Is the pressure plate stock? The service manual show a procedure I've never seen before for installing a pressure plate. There is a bracket that attaches to the flywheel and pushes in on the fingers of the pressure plate. It's supposed to be used when removing and installing the pressure plate. I wonder if there is an existing high performance pressure plate that could be adapted to use with the lightweight flywheel. I've been dreaming of doing this mod ever since I heard about it. What a drag. Comptech should help you out for using you car as a test mule. There's got to be a way to make this work. Hopefully they will get figured out.
that sucks allmotor sorry to hear about it.i have 6000 miles on the comptech clutch and no problemso far it kicks ass.maybe the flywheel they sent you was bad?anyway ill keep tabs on it but hope its not going to fail,i would think by now with all the hard launches i do between 1st and second and so forth something would have happened but so far im very pleased with it.well good luck and keep me posted as for what happens.again sorry to hear that.
so hypothetically if the CT flywheel was to work 100% properly on the CLS6, what would be the benefit of installing such item? What is the drawback of our current dual mass flywheel? Couldn't CT design something strong enough for this engine?
?? I'm not a mechanic...
The gadget helps align the clutch and tighten the pressure-plate at the same time... its not necessary to use as long as you use a clutch alignment tool.
I will chat with Comptech on Monday... its not like I don't like the flywheel... I definately do - I just don't think the current setup is strong enough for this car with mods.
It's a good think Types1967 has not had any issues... maybe I am the only one - we will just have to find out. I don't like having problems when I use mods from a reputable company - if I was 'inventing' some mod (like the turbo for example)... any problem is my own seeking!
thanks allmotor/chadT for the explanation...but wouldn't you think a company like Comptech would do some major R&D before releasing a product that can handle the current CLS6 setup? Sometimes I think automobile manufacturers have a great experience creating cars and if they included a dual mass flywheel, it must be for a certain reason. Perhaps due to the power of the current engine...
damn, hope you (allmotor) can get your money's worth here...my motto has always been "if it ain't broke, don't fuck with it"...but then again, my ass is not a mechanic and shit, I only do oil changes...
Before we all go off the deep end let's just consider that this might just be a case of one defective flywheel not poor design etc.Since no one else has had any issues that I have been made aware of it could just be a one time failure .
I certainly hope that when CT has been given the opportunity to examine the failed parts they will make a determination as to what went wrong and if it is a faulty part that they do the right thing for Allmotor. Meantime like I have said many times before let's keep our heads folks .
Jens
Jens
Jens
Jens
Comptech has been helpful so far in the matter... its just that I am led to believe there was some undue stress on the pressure-plate with this design. Now... it is also possible my pressure-plate might have been faulty... that I really can't determine. I just hope Comptech doesn't come back with "Well, you must have broken the pressure-plate during the install of the flywheel". If its a defective pressure-plate... I can't take it to Acura either!! This puts me between a rock and a hard-place. I can't quite imagine the issue being a defective pressure-plate.
I was pretty clear in my message to Comptech that this is an unfortunate situation and I just want it resolved (at this time, putting the stock flywheel back on is what I would like to do) without any more significant expense on my part. Plus, I don't want to sit on a $900 flywheel that is useless to me! On top of that, I have to buy a brand-new clutch/pressure-plate and pay for the associated labor - its right around $1500 already. Plus, I haven't had a car to drive for nearly a week and I don't see it back to me for the rest of this week either.
I am not ripping on Comptech... just that based on this experience, I don't feel this product qualifies as a suitable replacement (performance enhancing replacement) for the OEM design.
Trust me... I LOVED the performance gains of the flywheel. I was pretty much one week from taking it to the track on slicks and I am positive it would have hit a 13.2 E.T or better NA. If anything I am glad this happened now rather than on the track with slicks as the damage would probably have been much worse... or if it happened at 80-100mph... well, you know what happens then.
Sorry to hear about this! I hope Comptech owns up to this and makes it right
Quick question: I know with the Z which I am more familiar about the lightweight flywheels, the performance gains are negligable, even with the 14lb flywheel (stock is close to 30lbs). Did the Comptech flywheel really improve acceleration or just improve the throttle response and make rev matching quicker and easier? Is the stock unit on the CLS much heavier than the Comptech unit?
Much heavier from my understanding....
he's done more than just the clutch/flywheel.
Sick Spd Owner
Originally posted by allmotor_2000
Looks like the clutch/pressure-plate is on National Back Order from Honda!!
Tell me something i didnt know My belief is that they've had a few complaints, me being one, and they are fixing something, im gonna be looking at my invoice like a hawk to see if the part #'s are different. My car has been in the shop for 8 days and probably will be for a few more weeks. I got a pimp as cavalier loaner though. :ghey:
