Cold Air Intake on 2003 Acura CL
I just installed my AEM CAI which I had to remove the VSA(?) in order for the part to fit. I wanted to ask those member who have or had installed a CAI on their CL if they had experienced any problems either with weather or wear & tear. I just want to be caution of what I may experience. All information if much needed.
Thanks!
Thanks!
You should not have had to remove the VSA. If you did you got the wrong part. There are 2 parts, 1 for a 6MT 1 for the auto.
Only thing I can think of is the little metal tab that bolts the pipe down where the stock airbox was. Sometimes that will break off with age.
You will not have any problems with water unless you drive into a big puddle. Normal driving will be fine.
Also good looking on the water information. I was worried that if it rained or if I drove through the car wash that I am putting myself at risk of getting water into my engine.
Exactly!
Very interesting, I never considered doing that. Thanks I will have to give that a try. It would make sense plus I can then get ride of my bright warning lights.
Sorry to hear that. Did you drive throw hug puddle of water? I am using one but still I am afraid that something may happen.
I Blaze Up In
The only time a bypass valve will save you from hydro locking is when the filter in completely sumberged in water which involves driving through water thats reaches to the top of your bumper. And i dont think you should be driving thorugh water that high anyway, bypass valves wont protect you against any amount of water other than being fully submerged. And also, everday rain isnt a problem for an intake, and if you have to drive thorugh a puddle just take your foot off the gas, so your TB closes and your intake doesnt suck up air. IMHO bypass valves were created to scare people into buying them, they're bullshit IMO, but thats just my . Everone has their own opinion on them
-Mark
-Mark
-Mark
-Mark
Cool.... I was thinking about getting my car lowered about 1 inch or 2 but was afraid that I would put myself at risk but thanks to you all for clarifying things. Now I am trying to figure out if I should upgrade my bulbs. I want them to be crystal blue. I know when I had my 1991 Acura Legend I replace my stock with 8k HID kit but with the CL from what I understand is that all I need is to replace the HID bulbs not the ballast.
I Blaze Up In
^^ The intake always stays open, but it wont pull any air in unless you step on the gas, which opens up the throttle body thus pulling air through the intake.
As far as HID's go, I did a little searching around and the nicest color comes from KAIXEN 6000K bulbs. Once they warm up they arent too blue, just a nice light crystal blue so you sont gotta worry about them looking .
Excelerate sells KAIXEN bulbs for I think $100/pair
-Mark
-Mark
-Mark
-Mark
A lot of people have had their AEM intakes crack right at the mounting bracket on the intake tube...
I also heard that if you have a CAI and you do drive through a big puddle, you just need to keep your foot off the throttle so it doesn't suck in the water splashing up.
