Is it a coilpack?
Is it a coilpack?
For the last 2-3 months I've been getting a cel but it would only last for a day or so and then go away. I ran the code it kept coming up as misfire on cylinder such and such or random misfire on multiple cylinders. Is this a bad coilpack?
Whats up with RDX owners?
Still happening? Is it the same cylinder over and over again or does it move around?
Or if it continually happens on the same cylinder swap the coil pack with another and see if the code follows.
Have you talked to Paul lately about it?
^i have when it first happened but I forgot what he said lol. I'm sure he mentioned coilpacks. I think I'm going to do the switch and see game or if I can find some for cheap I'm just going to replace all of them so I don't have to do that.
Sounds like a coilpack. Very common (see it almost weekly on the TL side, same symptoms)
Regional Coordinator
(Mid-Atlantic)
(Mid-Atlantic)
could be the distributor or the coilpack
wham bam thank you ma'am
456
i has a similar thing what happened more often. turned out to be an injector. when the car is misfiring. start unplugging coil by coil. if the engine starts to studer more than that coil is good. if u dont get any change in engine sound, that that coil u just pulled is the one that is bad
456
456
456
5th Gear
Hello guys, I am fairly new on this site but I am so happy someone told me about this site wish i had known about there a little bit soon like they say better late than never its been so helpful with problems and fix. I just posted the same exact problem in problems and fix trying to find out the problem with my engine lights just want to say thanks for the heads up on what the real problem could be I would definite going to look it to coil pack thanks again.
456
456
Eurotrash
Last week, I had two ignition coils suddenly go bad (at 111k). Initially I was SURE it was a really bad tank of gas, but my mechanic read the codes (misfire on 2 and 5) and swapped in two used working ignition coils, and problem gone....
(now shopping for new ignition coils, ~$40 for OEM...)
Thirstyturtle
03-02-2014 04:17 PM
pakn-heat
03-26-2013 08:49 PM
SatinSilverTypS
08-15-2005 09:47 AM
