How to Replace Spark Plugs
Old Sep 7, 2007 | 04:48 PM
adc's Avatar
adc
Make sure engine is cold!!!!!!. or...you run risk of stripping threads during removal.
Didn't want to start a new thread but since I didn't find the info on here I wanted I thought I'd write it up. Reading this ahead of time will save you time doing it believe me.
Remove the 4 capbolts on the coilpack cover. Note that the 2 center bolts hold 2 coil packs underneath. When you remove these two there is a stud threaded at both ends. The whole thing may or may not come out of the block. In any event it doesn't matter. This could happen to the two others as well. Wrench size 10mm.
After removal the coil packs are visible. #2 and #4 coil packs have bolts holding the coilpacks in place-remove them. If the studs for the other 2 don't come out..remove them as well. Bottom line remove all 4 bolts holding coil packs. Next move the coilpacks counterclockwise and clockwise to the extent possible to break bottom of boot lose from the top of plug. This will allow you to pull the coilpack and boot out easier.
Push in the right side of the tab (see below and at the same timd pry off connector with a flat blade screwdriver. Twist it slightly in the space between the connector and the coilpack. This is the most difficult part of the job.
Move the connectors out of the way. Pull up on the coilpacks until they and the lower boot come out.
Next get a flashlight and look in all of the holes. If you see any water or oil in the bottom.-Stop. Put the stuff back together and take it to the dealer. You're done.
Use a 5/8" spark plug socket and a 10" extension. Note: tape the extension to the socket so with duct tape so they don't separate when removing..this can be a PITA. Make sure the socket is fully engaged on the plug!!! Break the plug free proceed slowly and even after the first turn go coockwise a turn..this will make removal easier. Like I said turn slowly so you don't strip threads. Take at least 1 to 2 minutes removing the plug. Inspect the thread on the plug and clean it off. Lubricate the old plug * Run it back into the hole and insure it runs in all the way by hand. Remove it.
Check gap of new plug. Should be about .047" +/ .002". Put dielectic jelly around top porcelain ribs. ** Put antisieze on plug thread *. Install plug gasket. Before putting in plug- check the sealing area of the top of the plug hole and if dirty use rag/extension and clean it up or use vacuum. Make rag slightly damp so that it picks up dirt.
Install plug. Make sure you use only the extension and your hand..no wrench. After it tightens by hand. loosen it a couple of turns and redo it (to make sure it stops at the same place. Torque to 10 ft lbs to make sure you are not overtorquing. Then torque to 13 ft lbs. note: max size click type wrench is 50 ft. lbs. Make very sure you see the "click"..its very slight with a 50 ft. ob wrench.
Put dielectic on bottom inside of boot and around the top where it engages into the valve cover housing. ** Install coil packs/boots and insure they bottom . Install the connectors by pushing it on coilpack til it clicks. Install the coilpack bolts just snug. Note you may have had to separate 2 of the bolts that double as coilpack cover.
Install cover you're done. Note.: I was very careful to clean everything up really good and was careful to cover the holes so nothing could get in the cylinders.
* Otional. Some recommend no lubricant.
** Also optional. I just do it.
Old Sep 7, 2007 | 04:53 PM
adc's Avatar
adc
Damn..pictures are too big. I'll work on that later.
Old Sep 7, 2007 | 06:24 PM
PACman's Avatar
Nice write up. I've got about 30K miles to go before I do this.
Old Sep 7, 2007 | 06:44 PM
adc's Avatar
adc
Thanks.. This was done at 70K miles and plugs didn't need changed. I wouldn't ever put old plugs back in though.
Old Sep 7, 2007 | 06:48 PM
adc's Avatar
adc
Manual Tranny Oil plugs.
Me again .Book isn't very clear. Anyone have pictures of the Fill, check, and drain tranny plugs. Looks like the two top ones are accessible through the Wheel well and the bottom requires a mail 3/8" male square drive to remove.
Thanks.
Old Sep 7, 2007 | 07:37 PM
aaronng's Avatar
Driver/Detailer
The fill and check holes are the one and same.
PACman's Avatar
Thanks.
Pics are further down the thread on this link...
https://acurazine.com/forums/showthr...mission+change
Old Sep 7, 2007 | 08:35 PM
adc's Avatar
adc
Hmmm...seems to be different from mine. I'll have to check it in daylight. It seems like there are 3 plugs altogether.
Thanks for the responses.
Old Sep 7, 2007 | 10:25 PM
redsox748's Avatar
thanks alot i had no idea how to fucking do this until now thanks guys.
Old Sep 7, 2007 | 10:59 PM
davidspalding's Avatar
Make a hole, coming thru!
A trick I do on boards is use a smaller pic, and wrap the smaller pick in a URL tag to the larger one. I did this today in the "member pics" thread.
URL=[larger pic url] IMG [img url] /IMG /URL
Old Sep 8, 2007 | 07:24 AM
adc's Avatar
adc
Since I could no longer edit: This will make easier reading.
Use a 5/8" spark plug socket and a 10" extension. Note: tape the extension to the socket so with duct tape so they don't separate when removing..this can be a PITA. Make sure the socket is fully engaged on the plug!!! Break the plug free proceed slowly and even after the first turn go clockwise a turn..this will make removal easier. Like I said turn slowly so you don't strip threads. Take at least 1 to 2 minutes removing the plug. Inspect the thread on the plug and clean it off. Lubricate the old plug * Run it back into the hole and insure it runs in all the way by hand. Remove it.
Install plug. Make sure you use only the extension and your hand..no wrench. After it tightens by hand. loosen it a couple of turns and redo it (to make sure it stops at the same place. Torque to 10 ft lbs to make sure you are not over torquing. Then torque to 13 ft lbs. note: max size click type wrench is 50 ft. lbs. Make very sure you see the "click"..its very slight with a 50 ft. ob wrench.
* Optional. Some recommend no lubricant.
Old Sep 8, 2007 | 07:31 AM
adc's Avatar
adc
You are welcome. If it helps one person the effort was worth it.
Old Sep 8, 2007 | 09:08 PM
aaronng's Avatar
Driver/Detailer
You can always get a lower rated torque wrench that starts from 10 ft.lbs.
Old Sep 9, 2007 | 03:51 PM
adc's Avatar
adc
Well mine is zero to 50 ft-pounds. But a zero to 250 inch-lbs dial type would be ideal.
Old Sep 9, 2007 | 07:07 PM
peterjedi's Avatar
Denso Website saids gap should be 44. Did you get the 47 from the book?
Old Sep 9, 2007 | 07:37 PM
adc's Avatar
adc
Actually I got the number from the Haynes manual for the 2003 to 2005 Accord. They called for .047 to .051 I just checked the gaps on the new Autolites I put in. They were pregapped to around .046 or so. I won't regap a new plug unless its way off. They are gapped at the factory to perform as specified. You always run the risk of damaging the electrode/insulator or the prong. But that's just me. Not saying its the final word.
Old Sep 9, 2007 | 11:56 PM
studville's Avatar
Doesn't Rice His Car
Hey thanks a lot! It helps me out for sure. I had no idea how to do this. IMO DIYs are always welcomed here whether someone has done it already or not. I've found from the DIY's here that I've read that some will have better pictures/descriptions than others.
Old Sep 10, 2007 | 07:23 AM
aaronng's Avatar
Driver/Detailer
That's about 1.1 mm, which is the right plug gap for our aussie version of the TSX. It's also the same for the UK Euro Accords.
Old Sep 10, 2007 | 12:48 PM
evil_acura's Avatar
anyone know the gap for the ngk laser iridium plugs?
Old Dec 29, 2007 | 11:12 PM
coondog64's Avatar
The NGK Iridium plugs come pre - gapped and arent menat to be adjusted. So you should be all set.
Old Apr 18, 2009 | 12:17 PM
Dan Martin's Avatar
Photography Nerd
Bumping this thread because I'm overdue for a plug change...
Does everyone still recommend the OEM iridium plugs? Also, has it been confirmed that they are pre-gapped from the factory and shouldn't be changed?
Thanks!
Old Apr 18, 2009 | 12:29 PM
wong05tsx's Avatar
Need more room in
at what mileage are you guys changing your spark plugs at?
Old Apr 18, 2009 | 12:40 PM
PACman's Avatar
Thanks!
Yea, Denso or NGK Iridiums have been continually recommended by many members. When I replaced mine, the plug gap was spot on, so I didn't need to adjust it. But I'd still double check the gap just in case.
Old Apr 18, 2009 | 12:42 PM
PACman's Avatar
Although our manual recommends plug replacement at 110K miles, I did mine at 100K. When I inspected the old plugs, the tips still look good with very mild carbon build up, so I guess I could of waited until 110K.
Old Apr 18, 2009 | 01:51 PM
Dan Martin's Avatar
Photography Nerd
Thanks. I just hope that the plugs haven't seized in the head because I don't think they've ever been removed in the 5+ years I've owned this thing. I've always changed my plugs after a couple years in my previous cars.
Fingers crossed....
Old Apr 18, 2009 | 04:30 PM
Miamicarfan's Avatar
Isn't the service interval for the spark plugs 110k or every six years?? Whichever comes first? So if I average 12,000 miles a year, i would have to change them at 72,000 miles right?
Old Apr 18, 2009 | 04:50 PM
curls's Avatar
Someone stole "My Garage"
Dan, and all others: ALWAYS check the gaps on plugs each time you handle them, even if they're fresh out of their packaging. My trustworthy parts counter guy I deal with has seen MANY plugs that look ok and were from boxes that look ok, be way out of spec. He thinks that too often, warehouse workers or transport companies will drop a package, and it doesn't take too much force to put the gap out by even a small amount.
It's quick and free insurance to check and adjust the gap as necessary, each time you handle the plugs.
Old Apr 18, 2009 | 05:47 PM
Dan Martin's Avatar
Photography Nerd
Thanks curls. I don't have a gapping tool, but I guess this is time to buy one...
Old Apr 18, 2009 | 06:50 PM
poltergeist's Avatar
Which is why every NGK and Denso plug I've seen has a sleeve over the threaded end to protect the electrode in the package....
...and the Service manual specifically states to not adjust the electrode gap on iridium tipped plugs. If the gap is out of spec, you're supposed to replace with a new plug.
Old Apr 18, 2009 | 11:40 PM
curls's Avatar
Never seen a sleeve on the few packages of NGK's I've bought, but I may have forgotten about 'em. Redardless, better to check than not, right?
Old Apr 19, 2009 | 12:27 AM
I can only speak of the NGK and Denso plugs that I've replaced (probably several hundred over the years) that come in Honda packaging...they all have plastic or cardboard sleeves over the threaded end. Seen a few plugs with cracked porcelains due to rough handling but I've never seen one with an incorrect gap if it still has a sleeve on it.
Agreed that one should check the gap on any plug being installed.....but I'd be leery of "adjusting" the gap on the iridium plugs as I'd assume there must be some danger of fracturing the electrode if you try and bend it for more/less gap.
Old Apr 19, 2009 | 09:00 AM
JTso's Avatar
I also apply a small amount of anti-seize on the plug threads before installing.
Old Apr 19, 2009 | 10:25 PM
Make sure engine is cold when changing spark plugs??
This is the first time that I hear this. That if you change plugs when it is warm, it may strip the threads.
But guys, what happens if you take your car to the shop and you wait while they do it? The engine will always be hot.
Old Apr 20, 2009 | 01:39 AM
goddsmack's Avatar
The idea behind it is that newer engines have softer metals that the old cast iron heads of the old days (which weighted a ton). So when the engine is hot, the metal is even more malleable, so there's might be a greater chance of not exactly stripping but rather cross threaded them out. You just take it easy when you take out the plugs and it shouldn't be hard to just use your own hand to unscrew the extension. If you're having to use the ratchet with the extension after initially breaking them free, you've cross threaded.
If you cross-thread, you're next best bet is to tap and re-thread with a helicoil.
Old May 3, 2009 | 05:17 PM
Kevdog's Avatar
ADC is right on spark plug change
I would only add that to help getting the old plugs out more easily, blow out any debris that might be in spark plug hole, loosen plugs 1/4 turn only and then put a short burst of aerosol carb/choke cleaner down in the holes where the spark plugs are. Let sit for 5 minutes to dissolve the carbon rings that build up on the bottom of plug that can really make it a nightmare getting the plugs out and cause damage to threads. Changed mine on '05 TSX this afternoon and could tell there was a lot of resistance when beginning to take the plugs out. After doing the above they came right out by hand (via socket and extension) without the wrench attached. This is a technique recommended in some manuals and by two long time mechanics I work with. I have twisted off a spark plug in a car engine before and the first thing that happens is a cold sweat, the rest is no good either. I hope this saves at least one person a lot of headaches.
Old May 30, 2009 | 10:24 AM
lowend15's Avatar
6th Gear
good advice Kevdog...I'll be changing my spark plugs tonight...FYI my parts counter asked for my VIN to determine which spark plugs- NGK, or Denso. They sold me the Denso plugs. I didn't know why exactly it would matter, but I guess it does.
Old May 30, 2009 | 12:22 PM
lcrazyaznl's Avatar
CL9 ABP
Denso are still good plugs alot people over japan and asia use them.
I went back to ngk though since i bought them and had them lying around.
Old May 31, 2009 | 06:15 PM
lowend15's Avatar
6th Gear
Just changed my plugs after 75k. Plugs looked nasty on the ends, but it is probably just normal. Car didn't seem to run much different or anything, but maybe I'll get better gas mileage or something. If not, it is just a good measure anyhow. And I probably saved $200 over the dealer. Took me about an hour, getting out tools, to the end of the test drive. About as cost effective as putting in your own cabin filter (which by the way, my dealer charges 125 FREAKIN DOLLARS FOR!!!)
Anyway, I put some 3M copper anti-sieze on the threads. There has been a bit of discussion on various forums about this, about galvanic corrosion, and all sorts of mess. But between various recommendations and my own conclusions, I decided to use just a dab on the threads for safe measure.
http://solutions.3m.com/wps/portal/3...beGSGRCGLTDBgl
Apparently they did sell me the NGKs. That's fine with me, as that was what I would have bought anyhow. This was a great write up, and this whole site is awesome. I've officially become a shadetree mechanic due to the overwhelming competence displayed throughout this site!
Old Jun 20, 2009 | 06:59 AM
adc's Avatar
adc
Since I don't own an Acura..don't post on here much. Had to come back and read my own writeup bc I plan on changing the son's plugs again shortly. Vehicle now has 105K on it (about 35K on these plugs). I put the AutoLites on so I want to check them sooner. I need to decide on whether to go with the NGK's or not.
Old Jun 28, 2009 | 06:28 PM
adc's Avatar
adc
One additional. As per Subaru a reduced torque requirement (1/3 less) should be used if the threads are oiled. Anti-seize is a lubricant so it might be prudent to drop the torque value by a couple of pounds.
