testing coilpack?
Old Nov 29, 2005 | 10:53 PM
yoda's Avatar
testing coilpack?
I'm trying to figure out a coldstart misfire with my wife's '03 TLS. I want to check the coilpacks, but have not found anything in the forum that tells me what/how to check for.
Anyone have any ideas on how to check if a coilpack is bad?
TIA
Old Nov 30, 2005 | 07:43 AM
fsttyms1's Avatar
if its runing normal when warmed up, im not sure there is any way to test them. usually you check for an impedince or voltage if you suspect that its bad all the time.
Have you had the car pluged in to see which cylinder/s are causing the missfire?
Old Nov 30, 2005 | 08:12 AM
ou sig's Avatar
Boomer SOONER
the best thing to do would be to replace all your spark plugs (most likely the problem) if you are having a misfire problem - that would at least narrow it down a lot if the car still does it.
Old Nov 30, 2005 | 10:52 AM
S power's Avatar
2010 TL SH-AWD
If you suspect that its the coil pack then unplug each coil HARNESS one at a time, if theres no changes to the engine idle(the one you just pull out) then thats the bad coil. Makes sense?
Old Nov 30, 2005 | 11:31 AM
yoda's Avatar
If you unplug a coilpack when the car is running for sure there'll be a misfire. I'm gonna see if I can lookup the info via Mitchell or something.
Old Nov 30, 2005 | 12:36 PM
S power's Avatar
2010 TL SH-AWD
But since you said how can you test or identified that the coil is bad or not, that is an easy way of checking. For example , say your #5 cylinder is misfiring and your pulling out the others, So you pull out #1 coil and seem that the engine idle will drop or hesitate, then that one is working fine. Then you continue to the next coil, unplugging and reconnecting back on each one at a time.
Then you come across #5 and when you disconnect it, the idle is still the same(misfiring), WHY? because thats the bad one. It will misfire even with its plugged in or not.
Or like the the other said, test the resistance with the multimeter.
Old Nov 30, 2005 | 10:26 PM
yoda's Avatar
The problem is that it only misfires when it's coldstarted in the morning. And it only misfires for a little bit, so there is only a limited amount of time to do "testing."
I was talking to someone else about this today. It's true that the OBD2 should store misfires in the computer. But also, after x-amount of time of "normal" status, the obd2 will clear out the misfires. So I actually borrowed a computer and will hook it up to the car in the AM and see if any codes come up right away. Otherwise it's almost next to impossible to figure out.
MrHeeltoe
20
Feb 23, 2023 01:54 PM
joflewbyu2
Aug 18, 2019 10:38 PM
emailnatec
29
Sep 28, 2018 04:27 PM
MrHeeltoe
Sep 29, 2015 10:43 PM
MrHeeltoe
Sep 28, 2015 05:43 PM
