Clutch is soft
Old 07-01-2007, 04:00 AM
Unregistered user
LIPPSTUH's Avatar
Clutch is soft
The clutch pedal has been getting softer and softer in the past 2-3 months. i checked the fluid and it's full. is there a way to make it more firm. its SO SOFT!
Old 07-01-2007, 05:09 AM
w202 on carlssons
ll1l2l1l2lll's Avatar
you should let me drive it and feel it. you didn't say anything about it today -___-"
Old 07-02-2007, 12:57 AM
Unregistered user
LIPPSTUH's Avatar
psh no donald
Old 07-02-2007, 03:05 AM
Blown is Best
Allout's Avatar
S/B self adjusting.
Old 07-02-2007, 11:00 AM
Unregistered user
LIPPSTUH's Avatar
s/b? please explain.
Old 07-02-2007, 02:11 PM
THE J35A2...
SIRSIG's Avatar
mine is not...
Old 07-02-2007, 04:51 PM
I'm a Vagiterian.
All Mine's Avatar
Mine's real soft for some reason. It's also notchy. It clicks every couple millimeters as I push it in.
Old 07-02-2007, 04:54 PM
fsttyms1's Avatar
Received 3,063 Likes on 2,119 Posts
You could try re-bleeding the system
Old 07-03-2007, 03:19 AM
Unregistered user
LIPPSTUH's Avatar
any DIY? i'll try that and get back to you. mine is not notchy.
Old 07-03-2007, 10:02 AM
fsttyms1's Avatar
I dont know if there is a DIY here or not, but its just like bleeding a brake. Attach a hose to the slave cyl and have some one assist by pushing in on the clutch. also making sure that the clutch reservoir doesnt go empty
Old 07-06-2007, 04:51 AM
Unregistered user
LIPPSTUH's Avatar
i looked into a few DIY/tutorials. looks simple... kinda.
but the thing is, there has been and still is full fluids in there, so i don't understand why there could be air... could it be something else?
Old 07-06-2007, 08:02 AM
Moodist's Avatar
One of my other cars is a M/T, the clutch started to get real soft. A month later it started slipping 3rd and 4th gear. How many miles do you have on your clutch?
Old 07-06-2007, 10:53 AM
Unregistered user
LIPPSTUH's Avatar
33,000
Old 07-06-2007, 02:52 PM
Moodist's Avatar
Hmm...33k is not much. I get the car back today, I will tell you what he says about
the clutch being soft. Today the mecahnic said in addition to the clutch, he needed
to replace some seal.
Old 07-07-2007, 12:43 AM
Unregistered user
LIPPSTUH's Avatar
ok thanks! hope to hear from you soon. ask him what can make the clutch soft. i checked my clutch fluid, its still there... dark though... but there.
Old 07-12-2007, 11:17 AM
Unregistered user
LIPPSTUH's Avatar
i just saw in the BM someone replaced their clutch at 52k.... wow.
what's the average life of our clutch?
Old 07-12-2007, 03:00 PM
Blown is Best
Allout's Avatar
It really depends on how it's driven. I think others have put over 100K on the original clutch.
Old 07-13-2007, 08:51 AM
Moodist's Avatar
Lippstuh - The mechanic didn't rebleed the system, the clutch and the pressure plate were replaced. Also the flywheel was resurfaced (this cannot be done for the cl dual mass flywheel). Also the rear engine seal was replaced, a little bit of oil was falling on the clutch.
Did you buy your car used? Since you only have 33k, take it to the dealer, see what they have to say. The clutch fluid shouldn't be dark, it is usually golden brownish. I don't see why it would get dark anyways.
Old 07-13-2007, 10:12 AM
GreenMonster's Avatar
Ryan, I hate to have to remind you, but you don't have a 6spd... you still have a 01 5at CLS remember ??
Old 09-19-2007, 11:45 AM
Unregistered user
LIPPSTUH's Avatar
will i be covered under warrenty?
last time i brought my car in for the srs they billed me assholes...
Old 09-19-2007, 05:21 PM
For a Clutch ?? No... it's a normal wear and tear item like tires and brakes...
I've got 65K on mine, and it's not what it used to be, so I expect to have to replace it before 100K...
Old 09-19-2007, 05:48 PM
In the Mid-South meow
SuperTrooper169's Avatar
Received 2,162 Likes on 1,099 Posts
Could it be something as simple as the clutch pedal spring being stretched out over the countless times you press and release it? Just a wild guess.
Old 09-19-2007, 07:13 PM
Unregistered user
LIPPSTUH's Avatar
its a spring? i really don't want to bring it to the stealership... esp when it's not under warrenty. i guess i'll rebleed the system, probably reinstall the cdd.
i always thought it was more of pressure that makes it stiff. while bleeding the system there is no pressure. you just press it and it's stuck on the floor.
SidhuSaaB
05-30-2020 12:40 AM
knight rider
03-04-2016 08:59 AM
MilanoRedDashR
09-24-2015 11:04 PM
Quick Reply: Clutch is soft
