Clutch Replacement
Old Apr 30, 2007 | 01:28 PM
gc86's Avatar
Advance
Clutch Replacement
I think im clutch is slipping on my CL-S6... whenever I shift fast and pop the clutch and gas, the rpm's will jump up like the clutch isn't engaging. Are there any aftermarket choices available? or am I stuck with the OEM setup. And if I went OEM what would I need to replace? for ex. the flywheel/pressure plate/friction disk. Thank's for the help. And the car has 81k on the odometer.
Old Apr 30, 2007 | 01:48 PM
TheWeez's Avatar
I Wanna Beer
SPEC makes great clutches. They offer them for our cars. Pricing isn't bad either.
Old May 1, 2007 | 01:18 AM
gc86's Avatar
Advance
Damn 600~ for a clutch from SPEC? how come clutches for CL-S6's are more expensive than other cars?
Old May 3, 2007 | 02:59 PM
gc86's Avatar
Advance
I went over and toke a look at acuraoemparts.com and found a clutch set for $234, is this all I need for a full replacement? I believe it includes the pressure plate and clutch disk. What else should I replace? the throw-out bearing? here is a list of replacement parts for the transmission. http://www.acuraoemparts.com/delray/...All&vinsrch=no Could someone point out what else I should replace?
Old May 3, 2007 | 05:58 PM
fsttyms1's Avatar
You may need the flywheel as well. Our flywheel is a Dual Mass unit and cant be machined.
Old May 3, 2007 | 06:29 PM
TheWeez's Avatar
I Wanna Beer
You might wanna do the throw out bearing while your in there too.
cobra10363
Jul 23, 2024 04:13 PM
cycdaniel
Dec 17, 2019 10:58 AM
niray9
Dec 8, 2015 07:34 PM
mugen_kid
Nov 13, 2015 10:38 PM
heyitsvic
Sep 4, 2015 09:38 AM
