Clutch Alignment Tool
Old May 22, 2007 | 08:15 PM
Cocoa's Avatar
2600lb CL
Just as I finished installing my clutch and pressure plate, I realized I did it without the clutch alignment tool. Went to the box and saw that I didn't get one. So I went on the acuraautomotiveparts.org site and saw they didnt have one listed.
Anyone know where I can buy one online? Anyone have a spare one I could buy off of? I can't believe I almost threw the tranny on without doing this properly.
I'll be driving to my local autozone, but I highly doubt they'll have one to sell seperate from the clutch. Worth a try though...
Old May 22, 2007 | 08:18 PM
hornedfrog2000's Avatar
B A N N E D
Maybe you could buy a kit use it, but keep the tool really clean, and then take it back...lol Thats what I would do.
Old May 22, 2007 | 09:16 PM
Allout's Avatar
Blown is Best
Autozone should have one. Just measure the input shaft diameter on your gearbox.
Old May 22, 2007 | 09:25 PM
Cocoa's Avatar
2600lb CL
Just went, they said it was a dealer item only. They were going to take one out of the clutch kit for me, but they dont carry the clutch at all.
Old May 23, 2007 | 12:15 AM
SIRSIG's Avatar
THE J35A2...
or you can use your broken axle as an alignment tool...
Old May 23, 2007 | 12:19 PM
Cocoa's Avatar
2600lb CL
http://www.clutchtools.com/index.php?shopping_cart=yes
For those of you that will be changing your own clutch, I finally found the tool. Above is the link to where you can buy it. It's only $10 shipped.
Cocoa's Avatar
2600lb CL
Dealership tried telling me it was $55 and it would take WEEKS to receive it.
Old May 23, 2007 | 01:00 PM
Zippee's Avatar
You can also make one out of a wooden dowel. For the RX7 I used a piece of broomhandle...fit well enough to align the clutch.
Old May 23, 2007 | 01:06 PM
Cocoa's Avatar
2600lb CL
I looked around the garage, but no luck. Although, I never thought about using our broom. Oh wells, tool should get here in time for the weekend I hope. It's not like this car is going anywhere soon. I just have to make sure I finish everything before the All Cali meet on the 30th of June.
Old May 23, 2007 | 01:08 PM
Cocoa's Avatar
2600lb CL
Btw, I forgot to mention, I found a 6 puck clutch in my tranny. I was actually surprised I had one. Aidan told me he was going to get me an aftermarket clutch, but figured I was scammed after months of my car sitting at his shop for the swap. Only lasted 1 month though, so that's not good, either that, or it was already in the tranny when I bought it off the guy from FL.
Old May 23, 2007 | 06:35 PM
fsttyms1's Avatar
I made my own from a dowel. All you need to do is keep it centered long enough to start tightening the pressure plate bolts.
Old May 23, 2007 | 07:24 PM
tankmonkey's Avatar
6 speed...
my helms specifies using a "pressure plate compressor" (07aae-p8ea000), "clutch alignment shaft" (07aaf-p8ea000), and "pressure plate compressor adaptor" (07aak-p8ea000) to align and pre-load the pressure plate when reinstalling the clutch (see page 12-12).
it sounds like other folks have made it work without these parts (ie, dowels, etc.), but I know my car was undrivable from the dealer when the tech failed to follow this procedure when changing my clutch.
no one has mentioned it yet, so Im not sure how important it is, but I thought I'd point it out just in case.
the service writer at the dealer also mentioned that the only other acura (at the time this was done) with this issue was the nsx, so they didn't even think to look for it on the cl-s.
SidhuSaaB
May 30, 2020 12:40 AM
emailnatec
29
Sep 28, 2018 04:27 PM
Jul 16, 2017 07:33 AM
knight rider
Mar 4, 2016 08:59 AM
