Clunk when going from P-R?
Old Apr 30, 2004 | 09:27 AM
ktgumbo's Avatar
Balla on a Budget
Does anyone else have this problem when going from Park to Reverse? This happens in my moms TL. I dont think it is a tranny issue cause it is driving fine. Is it normal because my CL does that sometimes as well.
Old Apr 30, 2004 | 09:34 AM
anothercls's Avatar
I have a clunk problem when I put my brakes on, this started after they replaced the pads....
annoying to me, but havent had it back in since then.
Old Apr 30, 2004 | 09:48 AM
Rock2534's Avatar
are you on a hill when this happens, mine will do that but only if i am on an incline of some sort. Feels like the weight of the car is resting on the gears, so you have to give it some force. But I have seen this in many other cars as well.
Old Apr 30, 2004 | 11:45 AM
donduncan's Avatar
go go go go go
Its the transmission changing gear. It makes a click like manual trannys when shifting to reverse
Old Apr 30, 2004 | 12:03 PM
Slooo97CL's Avatar
when parking: press the brake, put the car in Park (still holding the brake), pull the ebrake, let go of the brake.
when leaving: press the brake, release ebrake, put in gear and go.
sounds pretty retarded, but that will solve clunking issues.
Old Apr 30, 2004 | 01:25 PM
Rock2534's Avatar
i got you, so you don't let it roll that little bit when you take your foot off of the brake and let it rest on that gear. makes sense.
Old Apr 30, 2004 | 01:39 PM
juniorbean's Avatar
Correct... even the slightest bit of roll while shifting will cause that clunking sound....
Old Apr 30, 2004 | 01:47 PM
Gabo3k's Avatar
The sound actually comes from loading the gears with some of the weight from the car. All cars are engineered to withstand these pressures.
However, it is good practice to not load the tranny with any weight while the car is not running.
The instrucitons above will solve your problem.
Also, when parking on an incline:
While stopped, and while depressing the brakes, place the transmission to the Neutral position "N". Depress the parking brake firmly. Test the parking brake engagement pressure by slowly lifting off the brake pedal. If the car moves slightly, you must apply additional pressure to the parking brake. If the car does not roll slightly, you have enough pressure to leave the parking brake as is.
Continue by lifting completely from the brake pedal. Place the transmission to the park "P" position, and you are set.
As a rule, always apply more parking brake pressure than necessary (better safe than sorry).
I hate that clunking noise too.
If you have the same noise under various other situations, PM me and I can assist.
My cars transmission does not clunk now!
Old May 2, 2004 | 07:47 AM
power3dfx's Avatar
Parting out 02 Type S :(
well said, let the car rest on the ebrake before you get into park.
Old May 2, 2004 | 01:30 PM
flint's Avatar
Mine has a soft clunk even when parked on level. Pretty sure its normal.
Old May 2, 2004 | 02:31 PM
dragon084's Avatar
1999 CL3.0
^ im with stupid
Old May 22, 2006 | 04:57 AM
TeamMidnightinvasion's Avatar
Pres TeamMidnightInvasion
Mine tranny made a huge clunk sound when putting it into reverse with my foot on the brake on a incline, and then i went to drive on flat surface and put it into reverse and it made the same noise not as bad. It hasnt made the noise since but freaked me out.
Old May 23, 2006 | 10:03 AM
belcom's Avatar
09 TL SH-AWD
I got a tick when going P-R. Don't think it's normal and sounds like tranny. why it's doing it?? who knows...
Old May 23, 2006 | 11:30 AM
NSXNEXT's Avatar
It's normal. My TL has done that from day one (100K and still on original tranny).
Once the trans fluid warms up the clunk is not as pronounced.
Old May 23, 2006 | 11:59 AM
Acutron's Avatar
Skillionare
Same thing when I am on an incline seems pretty normal
Old May 23, 2006 | 01:36 PM
brianlin87's Avatar
ASM I.S. Design FTW.
how many miles on your whip now NSXNEXT?
marcelft
Jul 10, 2018 06:17 PM
Brandle34
Sep 23, 2015 07:20 PM
1Lieutenant
4G TL Problems & Fixes
Sep 10, 2015 08:39 AM
kansaiwalker1
Nov 18, 2006 11:36 AM
r3mix3r
Jul 20, 2004 06:04 PM
