clanking noise from the wheel
well... had my car checked out by the dealer today, good news that I am getting new side window regulator ( due to the problems of window making noises when going down )
But my clanking noise from the suspension ( I guess its related to sway bar end links )... they told me they fixed it, but I just checked and its still the same
Here is what my invoice says:
My problem descrption said "when going around 5-10 miles an hour and going over bumps there is a clanking noise coming from right rear must drive car with window down to hear noise"
Here is the invoice answer:
"417099 R&R Left side rear strut spring and lubricated spring dumper". They told me on the phone that this fixed the problem ( they checked )
Am I missing something? "... Left side rear ..." ?? The problem description clearly says that noise is coming from right rear... unless they have different point of reference...
Anyway, problem is not fixed ... even though I tried to suggest to them that they need to make sure sway bar end links are tight up...
What do you think should I do, am I crazzy or something, or they are not doing what they supposed to?
Originally posted by AkuraCLS
take it back and bitch
Dealer probably thinks I am crazzy that I am concerned about all those noises... but this car is to expensive for me... so I am trying to have things top notch ...
The mechanic needs to ride with me so I can point out the specific sound
The voice of wisdom....
When I had my sways put on, they supposedly took the car out for a "serious" test ride... I only needed to drive my car about 20+ feet to notice that racket coming from the bottom of the car. The sway bar links and sway bar brackets didn't get tightened and I didn't get any "help" until the mechanic got in the car and drove an extra 30 feet with me...
Test drives... yeah, right...
"Am I missing something? "... Left side rear ..." ?? The problem description clearly says that noise is coming from right rear... unless they have different point of reference... "
Some dealer personnel do have a different POR. I'm speculating that it's quite a challenge to determine left from right rear when one's head is stuck between the two.
Its clearly coming only from one rear wheel only when going over the bump... I checked, its not from trunk cause you can only hear clancking with open windows... you need to drive 5-10+ miles an hour and bump does not have to big... in fact, when road is full of small bumps that rear wheel sounds like bunch of coins(metal clancking) making noises.. it is pretty noticable.
What's funny, they told me that they found a problem, fixed it, and test it and noise was gone. ??
I am completly stock... but somebody told me that my stock sway end-links could loosen up... do you think this is the case?
You would think the noise would show up mostly when under differential load (the sway bar working its hardest... however, some people didn't find this to be true).
Don't know -- I would make sure you find a "local" road near the dealership (with low outside noise) where you can demonstrate the noise to the mechanic.
AS for the "problem fixed" and we found it.... Well, don't start me (good stories and way too long horror stories)...
