CL-S Performance upgrade help?
Old Feb 1, 2005 | 10:29 AM
racersir's Avatar
CLS 6 Speed
I'm trying to get a little more performance in my CLS 6 M/T. Right now all I have installed is a AEM CAI. I have Konig Trouble 18 inch wheels H&R OE Sports and crossed drilled rotors but I'm thinking a little more speed. What should I go next Headers, exhaust,etc? Also I'm thinking about the supercharger but what do I need before I get the supercharger? Will the stock clutch hold the supercharger?
please
Old Feb 1, 2005 | 10:32 AM
anothercls's Avatar
Headers will be the best bang for the buck, and is usually suggested prior to going to the supercharger. The stock clutch seems to hold up well against supercharged and turbocharged CL's.
Old Feb 1, 2005 | 10:42 AM
fuzzy02CLS's Avatar
Yeah Headers will do it. Your stuck with Comptech though. Those are the only ones that fit a 6 speed. Be prepared to spend about $1K for them.
Old Feb 1, 2005 | 10:44 AM
Louie11's Avatar
What he said ^ . Headers!!!!
Old Feb 1, 2005 | 10:50 AM
Chaptorial's Avatar
Here's your next mod:
Stay away from replacing the b-pipe and axle-back exhausts until you do decide to go with the S/C. Replacing them now won't yield any solid performance gains.
Some people were having problems with the Comptech Flywheel & Clutch Disc upgrade however everyone with the stock 6MT setup seems to be running fine. Its us 5A S/C'd guys that need to "worry" about drive train issues.
And really you don't need anything before you decide to go with the S/C, except maybe a pair of shades.
Everything you need comes in the kit minus a smaller 51r battery if you don't want to relocate your existing one to the trunk. Because of the space limitations in the engine bay due to the S/C a smaller battery is needed.
But no rush, start off the headers first. After that you can replace the stock Crank Pulley with an UR Lightweight one. That’s has shown some moderate gains. However if you do decide to go with the S/C you'll need to get rid of it because its not compatible with the charger.
Best of luck.
Old Feb 1, 2005 | 11:19 AM
RaviNJCLs's Avatar
Headers, definately.
Old Feb 1, 2005 | 12:15 PM
phipark's Avatar
Not Asian
If nobody said headers yet, get headers.
Old Feb 1, 2005 | 01:01 PM
racersir's Avatar
CLS 6 Speed
Are Comptech headers the best or are they just the only one? How much power can I expect from the headers? Where is the best place on the web to get them since I live in Puerto Rico and thanks a lot to all for helping this rookie.
Old Feb 1, 2005 | 01:06 PM
ThinJim's Avatar
Red face
I may be incorrect in saying this, but I believe the only people who had a problem with the comptech flywheel were a couple of guys who turbo'd their car. a turbo likes a heavier flywheel. I've had the comptech lightweight flywheel and clutch disk they provide, using my stock pressure plate, and have not had one problem with it.
I had the supercharger on it for the life of the flywheel and it revs up extremley fast and the bite on the clutch is as good if not better than the stock disk. I say this because comptech sourced out a clutch disk that is from what i was told by them is a different clutch disk material. none the less, it has given not one problem and would recommend it for the 6 spd guys, with or without the SC. I am now running the lightweight flywheel on the same car, but without the SC, and it revs much faster than the stock flywheel ever did. think about it, half the weight.
I'm a believer for the flywheel and am against the nay-sayers, god bless them.
Old Feb 1, 2005 | 01:25 PM
NSX-Tuner's Avatar
boosted is best
If you are going to install a S/C, your current AEM CAI would be replaced with the one from the S/C kit. To get the most out of the S/C, you should install CT headers and the CT full catback exhaust. As far as the stock clutch, I've been running the S/C (305 WHP) for over 25k miles without any problems.
Old Feb 1, 2005 | 04:29 PM
racersir's Avatar
CLS 6 Speed
I have seen the heades for about $1100 is this good price for the comptech? How does the car sound with the headers?
Old Feb 1, 2005 | 05:01 PM
phipark's Avatar
Not Asian
That's an okay price. The car doesn't sound that much different from stock.
Old Feb 1, 2005 | 05:14 PM
NiteQwill's Avatar
Adventurist.
Headers of course. The headers really don't change the sound at all.
Old Feb 1, 2005 | 10:13 PM
babyblue's Avatar
Sold but not Forgotten...
Headers is a must... Sound wont change but VTEC will be much better
Old Feb 1, 2005 | 10:55 PM
ou sig's Avatar
Boomer SOONER
Stone headers fit the 6 speed...and are much cheeper.
Old Feb 2, 2005 | 12:14 AM
dfv3.2CL-S's Avatar
CT headers all the way man. Felicidades Boricua en la compra de tu CL-S de 6 cambios. Is there alot of these car in PR. What is the price of one of those babies on the island. Are the prices close to 45K?
Old Feb 2, 2005 | 07:13 AM
racersir's Avatar
CLS 6 Speed
Gracias hermanito There are some CL-S most of the are the 5A/T I have seen only 2 CL-S 6 speed so far as for the price for 2001 are between 20k-25k and 2003 CL-S are between 30k+ and brand new was around 45k the prices of cars here are insame man but thanks guys for the advice I'm going with the Comptech headers first and then the S/C I will let you guys know how it goes.
Pham Alvan
May 18, 2021 06:48 AM
mlody
Dec 4, 2019 02:11 PM
c1souk
Sep 28, 2015 11:20 AM
ExcelerateRep
Sponsored Sales & Group Buys
Sep 22, 2015 10:39 AM
