CL-s engine in a intergra??
Old Jun 22, 2003 | 12:46 PM
Bobbydoedoe's Avatar
I'm Cool
hey my friend keep saying a cl-s engine will fit in a intergra, is this true? thx in advance
Old Jun 22, 2003 | 12:50 PM
MiK3Y's Avatar
i've seen an NSX engine in a Civic. it didnt just drop in without some cutting and pounding in certain areas, but it did fit. it was a drag car though, not a street car.
Old Jun 22, 2003 | 01:08 PM
Zapata's Avatar
Cost Drivers!!!!
although the NSX engine and standard i4 engines are 90 degree blocks. The CLS engine is a 60 degree engine so it theoretically should be wider.
Old Jun 22, 2003 | 01:22 PM
chikai's Avatar
trying to get a lil V-I
no way...plus they spin backwards from each other.
Old Jun 22, 2003 | 01:37 PM
allmotor_2000's Avatar
The rotation-direction isn't a problem... it can be done... imagine what this motor (6spd) will run in a Civic HB!?!
Old Jun 22, 2003 | 01:56 PM
mt6forlife's Avatar
NSX V6 is a 90 degree angle. The CL-S is a 60 degree V6. 60's are more compact than 90's. How does an inline engine have a V angle?!?!
Old Jun 22, 2003 | 02:17 PM
Ant7701's Avatar
Sweet as Gold
To all those that have seen a NSX engine on a stand out of the car...you know what I mean when I say that this engine is fucking huge!!!!!The NSX engine is larger in dimensions to most American muscle small blocks and maybe even some of the big blocks...not shitting you!!!! Just about any engine will fit in any car...as long as you have the money. A CL-S engine will definitly fit in an integra...not saying it will be a direct fit at all though and it probably wouldn't match the trans or anything....So if you replaced the ECU and wiring harness, trans, custom motor mounts and brackets, axles, radiator, etc....yeah then you could fit a CL-S engine in an Integra...
Old Jun 22, 2003 | 02:54 PM
Jens H.'s Avatar
retired
It can be done ,The biggest problem is not width but the height of the whole deal .Civics Tegs are very low slung cars relative to TL and CL vehicles .Getting that tall stack of a motor in is the problem .A 6 speed CL/S in a Civic HB is a wild idea but it will take some serious resources to pull it off (any takers?) .
Jens
Old Jun 22, 2003 | 03:26 PM
MiK3Y's Avatar
here are pics of the civic i was referring to. it was built by Signal Auto and as you can see, it's a tube frame car so i dont even know if it would fit in a full bodied car. the front end looks like it has been heavily modified to get the motor to fit. so yes its possible, just not practical.
Old Jun 22, 2003 | 04:47 PM
SiGGy's Avatar
Moderator Alumnus
Hahaha a 90 degree inline 4cyl
Maybe you meant that differently... heh
Pham Alvan
May 18, 2021 06:48 AM
SidhuSaaB
May 30, 2020 12:40 AM
joflewbyu2
Oct 8, 2015 11:16 AM
ROSSARONIE
Oct 2, 2015 11:46 AM
STL TL-S
Sep 23, 2015 08:52 PM
