Check Engine Light came on
Started the car this morning and while warming up the car, the car started reving real funny. tach was slowly bouncing up and down, between 1K and 2.5k. restarted the car and it went away. this evening while driving, the car is real jerky when i let go of the gas. i put the car to neutral and the tach slowly bounces btwn 1K and 2.5K again. this time the engine light comes on with the tcs light. pulled to the side, restarted the car and now the check engine light won't go off. car drives kinda okay...at times the car would still be jerky when i let go of the gas. will have the car checked sometime this week. what could be wrong?
Originally posted by PiMpiN wHITe Cl-S
tranny goin bye bye..get it checked right away.
Originally posted by ModAddict
You could try to reset the ECU, but maybe take it to Auto Zone and have them pull the code first.
well, i reset the ecu by disconnecting the negative wire on the battery. reconnected and now the check engine light is off. idle seems normal at this time. seems to drive normally. will continue to monitor. could it be that the computer just got hosed up because of the cold?
It's the Linear Solenoid
Take the the dealer as soon as possible your linear solenoid has gone bad, that is part of the transmission that governs the shifting of the car...
The linear solenoid is probably out of the range that will be cover under warranty takes about 3 hours to replace!
hope this helps...
hope this helps...
Re: It's the Linear Solenoid
hope this helps...
hope this helps...
HeloDown
09-08-2015 06:51 PM
