Check Engine Light??
Old Apr 6, 2003 | 09:52 AM
Chief F1 Fan's Avatar
I'm driving home last night and my check engine light comes on. I know it's not low on oil or anything like that b/c it just got changed. I looked at it anyhow before driving any further and had a friend rev the engine while I listened for any odd sounds and nothing so I continue driving. Anyone know what this is? I did a quick search and saw something relative to a 3.0 CL and the oxygen sensor having carbon build-up on it and needing to have ECU reset. Is this the case here? Thanks
Old Apr 6, 2003 | 11:17 AM
awell007's Avatar
If the Acura OBD "On Board Diagnostic" system is anything like the Cougar's, I would:
A) Go to a local AutoZone (if there is one) and have them pull the code that was thrown. They do it for free, and it sure beats paying 76.00 (what Ford charges) to simply know what code(s) was thrown. From there they can clear it, and you should know what to do from there.
OR
B) Disconnect the battery for 20 minutes to reset the ECU.
The code should go away, and if there is a real problem it will come back on within 300 miles.
Old Apr 6, 2003 | 11:41 AM
SiGGy's Avatar
Moderator Alumnus
Is your gas cap on tight (three clicks)? It takes 3 trips of driving (10+ miles) to get the engine light to turn off from a loose gas cap once it is tightened.
Old Apr 6, 2003 | 12:16 PM
Scrib's Avatar
Administrator Alumnus
Check the gas cap.
Old Apr 6, 2003 | 02:56 PM
Doubt it's the gas cap, I'm really anal about the "3 clicks" thang. I'll disconnect battery cable right now while it's nice out and see what happens.
Old Apr 6, 2003 | 03:27 PM
success! thanks guys
Old Apr 16, 2003 | 05:26 PM
DJBOMBERMAN's Avatar
does your radio presets reset?
When you disconnect the Battery for that long it will reset erase all of my presets and everything on my aftermarket radio. If it doesn't that's cool, but if it does then oh well....just wondering if it did for you....
MikeYutkin
Sep 10, 2015 10:13 PM
Bahamanurse1
Sep 10, 2015 10:05 PM
HeloDown
Sep 8, 2015 06:51 PM
bryan zaragoza
Sep 8, 2015 12:28 AM
whitesoxsfan12
Sep 7, 2015 04:07 PM
