Check Engine Light
Old Mar 10, 2002 | 03:49 AM
Juker008's Avatar
TRELOS
Check Engine Light
This morning, around 430 hrs. Coming home I had my check engine light come on. It came on just as I was pulling into my neighborhood. I didn't pull in fast, just nice and slow cause I was tired and, boom the light comes on. My oil, for me, is 200 miles over due (3200 miles on it). I've got 27900 on the odometer. I have an AEM CAI that I haven't recharged yet, could that be a potential problem.
Any clue what it could be? Yea I know that I now have to take it to the dealer but just wanted to know if this has happened to anyone else. Just so that I can prep myself for the shit that I have to hear.
Tnx
Juker008
Old Mar 10, 2002 | 04:15 AM
mattg's Avatar
it could be a regular maintainance light that comes on every 6000 or so miles. not likely to be your cai. take it to your dealer for a checkup.
Old Mar 10, 2002 | 12:29 PM
Juker008's Avatar
TRELOS
Naaaa. Its not the regular maintanance light. Its the check engine light. The reason why I can't have my car in the shop is cause if Acura gives me a rental. They'll only give me $10 a day towards a rental. I remember back when I had my tranny replaced. All that $10 got me was a GEO Metro. And now that tourism is in season down here. For that same GEO Metro will cost me anywhere from $40-$60 (no this is not a typo). For a Ford Taurs $60-$90, adn for an SUV Ford Explorer about $110. So really Acura won't cough up $40-$60 just for a GEO Metro. But mabey they'll have a spare that I can rag on.
Juker008
Old Mar 11, 2002 | 01:08 PM
moomaster_99's Avatar
From: Somewhere between here and there, yet neither.
Check Engine Lights tend to be O2 sensors. Either you dont have one plugged in...or a vacuum line is loose that leads to the sensor...or maybe the one in your cat got broken...any number of things...basically, the light has to due with smog and air/fuel...until you get it fixed..your car will bog...as it is in running in safe mode which means lots of extra fuel to prevent any detonation that might be occurring within your motor.
Old Mar 11, 2002 | 01:10 PM
RandyMax's Avatar
Does anyone have a Hayne's manual? Does it tell you how to get the diagnostic code?
Old Mar 12, 2002 | 08:49 PM
Juker008's Avatar
TRELOS
PHUCKING BINGO!!!
Thats the same thing that I thought. And after today, including ur reply, I am for sure. I filled up today; 235 miles. TO THE TANK. Man I get at least 300 and that is average. And with my tranny (2nd) going out I get MORE miles to teh gallon. My previous tank was 352 miles. I have no idea why that when the tranny begins to go out that u get more mpg . If I could only figure that out I would incorporate that into my CLS.
Tnx
Juker008
Old Mar 13, 2002 | 06:25 AM
acura_service's Avatar
www.drippinwet.com
could be upwards of 300 things on OBDII
Old Mar 13, 2002 | 09:54 AM
Juker008's Avatar
TRELOS
Originally posted by acura_service
OBDII?
Sry been out of the loop for some time.
Plz explain.
Juker008
Old Mar 13, 2002 | 10:11 AM
NYKEEROCKA's Avatar
phuck your CL race my F4
when i got gas and did not click the cap at least 3 times the check engine light came on, i fix the gas cap and then the light went off in a day or so, it says after three starts it should go off.
Old Mar 13, 2002 | 10:42 AM
Chrisbert's Avatar
MP Video Extraordinaire
Yeah, try the gas cap. Make sure you click it 3 times.
Old Mar 13, 2002 | 11:00 AM
EricS's Avatar
Plz explain.
Juker008
http://www.obdii.com/
Old Mar 13, 2002 | 11:25 AM
scalbert's Avatar
OBDII = On-Board Diagnostics, second iteration. It is a standard set forth to make things similar across all vehicles. It primarily stipulates requirements for the air and fuel systems particularly when related to emissions.
But there are different status levels and a solid light indicates a minor failure. Major failures cause the SES light to flash.
Under the OBDII mandated codes there are over a hundred possibilities and not all are centered around the O2 sensors, only about 10 relate to those sensors. There are also hundreds more related to the specific manufacturer some of which may or may not light the SES.
The only way to know DTC which set the SES light is by reading it with a scan tool.
MikeYutkin
Sep 10, 2015 10:13 PM
Bahamanurse1
Sep 10, 2015 10:05 PM
HeloDown
Sep 8, 2015 06:51 PM
bryan zaragoza
Sep 8, 2015 12:28 AM
whitesoxsfan12
Sep 7, 2015 04:07 PM
