Changing front springs only?
Old Mar 23, 2004 | 01:58 PM
CLean's Avatar
Cars are an addiction
Hey all.
I just got a set of the H&R OE springs for my 03 CL-P.
They only thing I dont like about my car is that it sits much higher in the front (just shy of 1 inch) that the rear. The rear dosent sit that bad. So I was wondering, what if I was to just change the front springs on on CL with the OE Sport springs. I saw something about this done on a TL. And it gave his car a nice even look without hapering his car all that much.
Do you think it would effect the car if any to leave the stock springs in the rear with the OE's up front?
Old Mar 23, 2004 | 02:02 PM
dgracer's Avatar
You'll upset the balance of the car. By adding slightly stiffer springs to the front of the car without adding stiffer springs to the rear will cause the handling to exhibit more understeer than it already does. If you drive conservatively this wont be much of a problem but if you push it on on-offramps, you'll hate it.
Old Mar 23, 2004 | 02:09 PM
CLean's Avatar
I am a pretty conservative driver. I think. Not really intothe hard cornering.
But good point about the understeer. Never though about that... hummmm...
Wil it ride bad on normal straight roads?
Old Mar 23, 2004 | 02:17 PM
Red-CL's Avatar
Doin' da crack shuffle
You will definately have more rake than normal.
juniorbean's Avatar
I would even go so far to say that you will upset the balance of the car regardless of how hard you drive (or don't drive). Springs are meant to be matched, so you should install all 4 at one time. Using different springs will yield different spring rates, therefore, upset the handling of the car. Nevermind off ramps... how about a regular evasion (sp?) manuver? I would advise against it all the way.....
Either do it right or don't do it at all.
Old Mar 23, 2004 | 02:22 PM
dfv3.2CL-S's Avatar
Not a good idea at all.
Old Mar 23, 2004 | 04:39 PM
Six Shifter's Avatar
an adult perspective
I've done exactly what you are talking about to offset the addit weight from my system. B4 going to the Comptech fronts there was a measurable 1 3/4 inches more height in the front than in the rear. Jens at PAA suggested this route, and it does even the car out a whole lot better than it was, although there is a noticeable rake to it and it can look like the rear is riding on air shocks. Sometime this spring/early summer I will swap out the rears and add some Koni's to complete the install since I have just hit 40K miles in my '03 Type-S, but I have not experienced any ill effects at all - regardless of the driving situation.
However .... according to the experts on this site, it's impossible for me to be getting over 500 miles per tankful of gas on a regular, repeatable basis. Take it for what its worth.
Old Mar 23, 2004 | 10:59 PM
YuppieCL's Avatar
Moderator Alumnus
no way, just drop it all around. it'll look like a dune buggy otherwise
Old Mar 23, 2004 | 11:59 PM
TypeS_boi's Avatar
CL-S retired 10.17.06
so what's w/ the checkered flag avatar? C'mon...you know you drive your car hard! Anyway, it will look funny as hell and if you post pics of it...I'm sure people will poke fun at you! Drop the rear too!
Old Mar 24, 2004 | 11:23 AM
CLean's Avatar
ok ok ok... i am going to do the whole car. Maybe I will take it off the lift for a few pics with the ass end all jacked up. Then I will do the rear and take some more pics. So I guess I am going to drop it like it is hot... (is that the right saying?)
Old Mar 24, 2004 | 01:33 PM
dgracer's Avatar
I think it might ride a little better on normal stright roads since the front springs on our cars are a little soft in this respect (That is how you get a FWD to corner, softer front, stiffer rear springs). The HR OE's are also only about 10% stiffer than stock. While it is not the recommended setup for the reasons mentioned, you might like it. You could always do it in 2 passes. Do the fronts first, drive it around a few days, then do the rears if you dont like it.
I in fact run spring spacers in the rear of my 280z to stiffen them up and make it corner more neutral. I didnt want to overly stiffen the ride and lower an already low car and I like the result, even though it wouldnt be "recommended".
Feb 25, 2020 09:57 AM
divac
Aug 29, 2018 10:13 AM
08 NBP TL
Sep 8, 2015 08:49 PM
mav888
1G RDX (2007-2012)
Sep 8, 2015 11:49 AM
sputik
Sep 7, 2015 01:40 PM
