CEL Misfire on cylinder 5
Hello,
I started getting a CEL code saying random misfire and misfire on cylinder 5!
From the beginning… about 2 months ago I backed up and hit a parking stop and it F*** up my bumper and shoved my exhaust under my car. didn't think it caused any problems so i haven't fixed it yet! One night i misshifted and overreved my engine the next night i had a CEL code saying random misfire on cylinder 1,4,5. I took it to the shop they replaced all spark plugs and coil packs said they couldn't find anything wrong with it! I got the car back drove it around and sure enough same codes! I took it back to them the did a valve adjustment didn't see any bent or burnt valves! but they did say the insides of the cat are shoved toward the front I'm guessing from the parking bumper! i got it back drove it around and a code came back saying misfire on cylinder 5. could this be from the cat and it needs to be replaced? also my dad talked to a guy from the dealership and he said it could have jumped time??? but i think if it would have jumped time if would have bent a valve or something?? I don't know!! any one care to share on this?
I had the valves adjusted and they said there were no bent or burnt valves!!!!
you bent a valve while mis-shifting.
i can put money on it.
they just adjusted valve lashings and DID not look at the valves themselves.
a leak down test and a compression test will let you know RIGHT away if you have a bent valve.
perform a compression and leak down test!
then tell me why you're having misfires.
get the compression test done.
p.s.
Just last week, I let a friend drive because I was intoxicated.
He mis-shifted and Now I have a funny sounding idle.
sounds like she's cammed.
I already know its a bent valve.
and I'm looking for some heads.
SidhuSaaB
May 30, 2020 12:40 AM
joflewbyu2
Oct 8, 2015 11:16 AM
