CD's started jamming!!!
I've read about this but never had a problem....UNTIL NOW!! My home burned CD's now won't eject from the Bose. Had to struggle to get them out and scratched them in the process. Is this like an "old age" thing since my CL-S is an 01?? Damn.
Sick Spd Owner
I have the same problem with my 03. Seems to be limited to CD-R's with a more corse/rougher label. I have an old credit card that i use to help those guys out.
Sick Spd Owner
If you do what shawn does, you have no problems. The problem is a combination of extra thickness and roughness of the label. I started not putting labels on my cd's for the car.
I have the same problem with mine. The reason is cause i put labels on all my copied cds. Whenever I try to eject one of them and it's not coming out I just use this plastic business card I have to push down on the cd while it's trying to eject and then it pops out.
I have the same problem - every once and a while I have to do exactly what MRocks described. However, I don't use usually use CD-Rs, when it happens it's with factory stamped cds...
on a 10 mile ride
Be real careful with the markers used on the CD-R's. In the long run they will mess up the discs, even though only written on the label side. i write only on the clear center portion with a thin Sharpie. Besides, those stick on labels are too heavy and are never perfectly centered, messes up players and discs alike.
Save the labeling for the Jewel cases. check out www.ziplabel.com and get their cdrlabel program. Best I've found.
Our CD changer sucks, and is not durable.... Mine still works, but makes loud and abnormal noises while loading/ejecting CDs.... I feel it will brake very soon, I hope it will happen before warranty expires.
I've had a bunch of Verbatim CD-Rs get stuck ejecting from my deck. It's definitely a width problem. I never, ever put labels on them, but some brands of CD-Rs still stick. Never have I had an original CD stick. Just use a card or something to push up or down on the CD to get the wheels to grab again and force it out.
cycdaniel
12-17-2019 10:58 AM
cak165
1G TSX Problems & Fixes
09-16-2015 08:17 PM
