Car Shuddering???
Car Shuddering???
I got a question for all you gearheads. My 01 Type S (56K miles) shudders when iddling in PARK, but not when stopped at a redlight or at a stop sign in DRIVE. The shuddering isn't that bad, but I'm picky about my car. I guess it could be a number of things but any ideas off the top of ya'lls heads would be really appreciated. My thoughts are that it may have something do with 1. Transmission recall service done not too long ago OR 2. my car needs a fuel injection cleaning. New belts maybe?
Don't Mess With Texas
mine does that too i think...its not a steady shuttering just kinda every 10 seconds or so it will shudder for like 1.5-2 seconds...no one notices it but me so im just like
![Dunno](https://acurazine.com/forums/images/smilies/dunno.gif)
It is a pretty constant and soft shuddering, and no the lights don't dim. When I first start the car it doesn't ussually do it, but if I've been driving around for a few minutes and then put it in park in traffic or something then the shuddering begins. No one really notices it but me either but its quite annoying on a vehicle thats suppose to be a near luxury car.
Mine does the same thing, except it will do it in park, and it will also do it right before i come to a complete stop (its not a warped brake rotor shudder, its like an engine dipping to low in the revs type shudder). I have no clue what it is.
Originally Posted by kensukikatayo
my car shudders a bit when im braking when i got off offramps at like 70 or above, could it be the rotors?
![Yes](https://acurazine.com/forums/images/smilies/yes.gif)
Old&CnL
Then it's probably not the transmission; could be engine mounts, blown head gasket, air sensor, etc.
Best have a dealer do a code check and general diagnostic.
Turbo + Sound = Hey-pee
Boomer SOONER
it does not do when you first start the car because the car is running a cold start cycle...
do you have any Accesories running (A/C, heat, radio=system)
You mentioned something with your tranny... did you get the tranny replaced?.. if they replaced your tranny, they more than likely replaced your ECU as well.
where are your RPM's sitting at idle.. (20 minutes) after you start the car?
you need to go to the dealership and find out the problem and report back.
Boomer SOONER
it might be classified as a wear and tear item... ![Dunno](https://acurazine.com/forums/images/smilies/dunno.gif)
but my guess would be as long as you have factory warranty you should be able to get any problems rectified.
Beware of leakage
Thread for possible Idle/Shuttering/shaking/whatever else, RE: Throttle Body Cleaning
https://acurazine.com/forums/showthread.php?t=168014
Beware of leakage
Originally Posted by mystikk
My car's shuddering too, park and in neutral. Interior lights are dimming, and idle drops below 750. I do know the CL needs a desperate oil-change...
yea i always use 91, i jus got my oil changed and all the fluids refilled and its gone away, but it appears randomly sumtimes, i only have close to 55k
i jus checked wit my friend and he said my shuddering is from my torque converter trying to keep itself running, btw it only shudders when im in reverse and havent moved newhere yet
orkoTL
4G TL Problems & Fixes
107
09-28-2017 09:12 AM
