Which car alarms do you guys recommend?
I'm looking for a car alarm. Your suggestions are appreciated. I have an AT 01 CL-S. I've looked at some of the newer alarms that you can control from your phone. They seem to interest me the most.
all aftermarket alarms are a gimmick, ive had a $900 viper with remote monitoring, oe is the best for its purpose, unless you want remote start, then get that, although that just wastes gas
Whats up with RDX owners?
![](http://remtek.com/arms/glock/model/9/19/19.gif)
It makes just as much noise as an alarm but hurts a hell of a lot more.
LOL!
The stock system needs only a shock sensor or 2 added. You can add these yourself. They tie into the hood pin switch. Pretty easy. There's a DIY thread on them somewhere. The pics were dead last I found it. But the instructions are there. May be on the TL side.
Basically you get a DEI dual stage sensor. Splice the 2 sensor wires together making it a single sensor. Then tap into a wire to the pin switch at the back of the drivers side fuse box & then tap a unused +12v from a blank spot on the back of the fuse box, last wires goes to ground. Then mount the sensor, I tied it right under the steering wheel bulkhead. Set the sensitivity by banging on the windows from outside while it's armed.
On my car I added a 2nd shock sensor on the passenger side. That's even easier as you can wire the 2 sensors together & then connect both at the same time.
civicdrivr (01-06-2012)
When you say the steering wheel bulkhead, do you mean inside the car or in the engine bay?
Thanks for the tips
![rofl](https://acurazine.com/forums/images/smilies/rofl.gif)
Dee-bo, the greatest security system in the world.
Zonian22
11-14-2015 01:20 PM
Zonian22
09-02-2015 08:19 AM
Mugen TSX
Eastern Canada
09-01-2015 11:05 PM
