Can you guys help me with my CAI?
B A N N E D
Location: The grande.. Riverdale NJ.. Hopefully moving to skyline village in Lincoln park NJ..yes dirty jersey
I took my bumper off to replace my ballast last night and to clean/recharge my air filter. I had the CAI on my car since like 2002 and 20k miles , I now have 165K miles so it needed some TLC! I bought a rechager kit for $10 and did my thing. I am gonna invest in a new one and a new by-pass valve cuz the foam came of mine and the rubber broke. I took some pics can u tell me if u guys know the model # or what kind it is , I know its K@N!
![](http://farm4.static.flickr.com/3306/3441192269_01e419cbdc.jpg?v=0)
![](http://farm4.static.flickr.com/3642/3442005004_efb2553f02.jpg?v=0)
![](http://farm4.static.flickr.com/3619/3442005354_63ae1f2bbe.jpg?v=0)
B A N N E D
Yeah thats after i sprayed it with the cleaner, I let it soak in some car was soapy water then pressure washed it , now it looks aloty better but still want to get a new one when I change my by-pass valve!
B A N N E D
If I went with a longer wider one would it increase performance?
more area for air to come in = more air comming in, more air comming in = more HP...
Am I right or it will not make a difference if I put a larger cone filter on there?
wham bam thank you ma'am
its good to have a bigger filter to a certain point
if ur FI then having a bigger filter is better. for NA its what the engine can suck, so after a certain point a bigger one is pointless. really.
judging by the size of yours, get the same one a a bit smaller (length wise) if u want.
Whats up with RDX owners?
Check out the K&N website. Last time I was there I was able to type in the dimensions of the filter I wanted and got a part number.
B A N N E D
Funny the link to there webdite came up on the bottom of my post so I clicked it.
Do u guys think the 12" long one will be better or should I just stick with the 9" one.
Make sure it will fit behind the bumper.
B A N N E D
No thats b4 i sprayed the cleaner on it and soaked it and pressure washed it and sprayed the red silicone spray on it, it looks alot better now!
I still want to purcase a new one though for next time I have to drop my bumper!
be careful though. the longer the filter, the closer to the ground youll be which increases your chances of sucking up some water a little bit greater. just throwing that in there.
Received 1,080 Likes
it's a 3" diameter but as mentioned you might have clearance issues with a longer filter. Put the old one back on and see how much extra room you have.
OculiAquilae
11-19-2018 02:24 PM
