Can anyone help me identify this fitting?
Ok, so I just got my new CL and don't have a manual yet. I see what looks like a fitting down in front of the engine next to the mount. I'm wondering if anyone can help me identify it? I park on gravel and haven't felt like climbing under the car yet so I'm having trouble identifying when it goes.
Thanks in advance.
(yes I know the engine compartment is disgusting... It's going to be a long road to bringing her back :/)
Thanks in advance.
Whats up with RDX owners?
The little nipple? Thats the clutch slave cylinder bleed nipple.
Welcome to the 6 speed club btw.
Yes, the 6 speed ROCKS! Thanks
Thanks, and definitely... I'm already in love LOL
Quick question on the 6 spd... when I am up in RPMs, say above like 3K, and I let off the gas, the deceleration seems to be a little less smooth--more jerky--than I would expect... common for these cars, or might I have another issue to solve?
OK, thanks Rajca. Just trying to figure out everything and "assess" what needs to be repaired/tweaked... starting to detail the nasty engine bay this weekend, and the EGR valve if so motivated and the weather cooperates
Update for completeness... finally got some NGK lasers and found CHAMPION spark plugs in the damn car, with burned edges on the ceramic portion nonetheless! Replaced all the plugs and she is like a new car! The jerkiness at low speeds got 10x better.
I guess this is as an appropriate place as any to post since I haven't found a bleeding DIY thread yet with pictures... This is the nipple I would use to bleed the clutch fluid while I refill it with honda dot 3 brake fluid?
Then I would do the 4 brake nipples similarly... Driver Front, Pass Front, Passenger Rear, Driver Rear?
How many bottles of fluid should I have on hand to all 5 bleeds for a first-time "bleeder"?
Thanks everyone.
Thanks everyone.
Theres DIYs for bleeding brakes, the clutch is simple.
1)Attach hose to nipple
2)Put other end in a bottle filled with alittle fluid (stops air from going back up the hose)
3)Pop the clutch master cylinder cap
4)Top it off
5)Pump 10x, hold clutch to floor
6)Open bleeder screw, let drain until nothing comes out
repeat 4-6 until you get clean fluid
I forget the sequence for the brakes, but its the same method.
4)Top it off
Awesome, thank you CD... I'm waiting on a new bypass valve actuator and will complete the process once various engine components are all back together!
No problem. You will need a second person to pump and hold the clutch to the floor when you drain it, or you can get one of the one person bleeder kits.
lowrd on tein CS biatch
that front trans mount looks like is got some wear on the top... examine the bottom and see if its got any hairline cracks... If one goes, it makes the other 2's life THAT much harder so... i'd make sure ur front trans mount and ur passenger side mount is in mint condition.
that's my 2cents
that's my 2cents
Thank you.
If anyone knows of a good rust "converter" product I can use on the parts I can't remove just yet (such as clamps, etc. on the firewall) that won't harm the good paint/parts, I'd appreciate it.
that's my 2cents
that's my 2cents
Thanks everyone.
Thanks everyone.
Same fluid.
u can get SPEEDBLEEDERS
for the brakes.... so u can do it by urself
CHEAP METHOD and effective as HELL
http://www.speedbleeder.zoovy.com/
there is no listing for acura, but i'm sure they have the correct size, and just have not listed our car or brand there.
I was gonna get them but then just ran my car the the DLR to do it asap cause my fluid was assss brown. lol
Lol, its cool. I use to wonder the same thing.
Ya, no worries, I didn't know about it till this post Cool we can all learn together!
emailnatec
29
09-28-2018 04:27 PM
xsilverhawkx
09-28-2015 06:51 PM
