camber problems?
Old Apr 29, 2003 | 02:41 AM
kHmER Co's Avatar
mister D
camber problems?
i've had my car dropped for a whlie now, but since i had the 19's on. the fronts really butterfly'd, the inside of the tires seemed to be rubbing on something, recently i took them off and put the stocks back on, and its now the same deal with my stocks, the tires have a been noticablly worn on the inside, the cords show, is this a camber problem? or something having to do with the suspention rubbing against the wheels?
Old Apr 29, 2003 | 11:17 AM
AcuraTypeSboi's Avatar
either try getting a alinment or get ur chamber's checked, i had the same prolbem but it was all good after a alinment. tell me what happens.
Old Apr 29, 2003 | 11:20 AM
blazerbob1's Avatar
When I lowered my car had alignment problems. Only the rear was at spec limit and slightly over. Not a problem if frequent rotations are done.
Old Apr 29, 2003 | 11:28 AM
kHmER Co's Avatar
mister D
how many inches did you lower your car?
Old Apr 29, 2003 | 11:21 PM
My car is really low. I got the ebaich sportlines so thats like 1.75' in the front and 2' inches in the back. Its really low and i got the chamber kits for front and back. If you get a alinment and stuff, your ride should be ok.
Old Apr 29, 2003 | 11:22 PM
p.s. I also had 18's before and now i got 19's and no prolbems so far.
Old Apr 30, 2003 | 12:33 AM
haiduc's Avatar
Moderator Alumnus
it's your H&R's.
get a front camber kit, and get an alignment. your front tires are sitting like this /---\ instead of like this |---| so they are wearing the inside.
SidhuSaaB
May 30, 2020 12:40 AM
12vancover
Oct 16, 2015 12:04 PM
lanechanger
Oct 13, 2015 10:56 AM
Matthew Purpura
Sep 25, 2015 06:10 PM
0opie
Sep 22, 2015 04:15 PM
