caliper swap
2003 Acura CL Type-S
caliper swap
finaly got the 95 Legend Calipers in, stopping power increased but just had one problem while doing it the screw that goes into the back of the caliper was a bit leaky but its all good now
Whats up with RDX owners?
How did you stop the leak? New washers?
yeah just a new washer and that did the trick but right now i just got on the freeway and when i braked my steering wheel still shakes but its most likely because i didnt change the rotors right?
Yea, your rotors are most likely warped.
EBCs get rave reviews. I liked my Racing Brake rotors.
Its a simple bolt on. You can even use your stock pads.
I bought my legend calipers from autozone. They were closr to 100 each plus taxes. Then you can return your stock calipers for the core fee and get 44 back per caliper. It ended up being 52 each plus the tax. If you dont do the core refund i think it comes out to about 205 with tax. I am waiting to get my second set of legend calipers plus my stock rears back from the powdercoater. I got all 4 plus the brackets powdercoated in semi-gloss(satin) black. It is gonna cost me 100-125 for that.
dam i should of got mine powdercoated well i still got the cores in my trunk ive been a bit lazy to drop them off even tho i work at the place were i bought them at haha
Regional Coordinator
(Mid-Atlantic)
(Mid-Atlantic)
(Mid-Atlantic)
(Mid-Atlantic)
any special tools needed to do the swap? as in, what type of wrench do you use to remove the brake lines?
Use 10mm flare nut wrenches for brake lines.
![](http://www.nationalwholesaletools.com/ProductImages/full/113.jpg)
Is there any other options for the rear calibers as in a stock upgrade from another model Acura?
Hes asking about the rear.
And right now, no.
And right now, no.
I would rather do the 2nd gen rl calibers in the front, to me that seems like it would make a big difference but I wish there was a option for the rear so it could match..
(Mid-Atlantic)
(Mid-Atlantic)
Thanks Morgan, exactly what I was wondering, I have a set of these from when I did my fuel filter, wonder if I have a 10 mm ![Ponder](https://acurazine.com/forums/images/smilies/ponder.gif)
Read before trying to answer questions, he's talking about the rear
if you want a front plus rear bbk then get the rotoras. Not worth the money imo unless it is a show car. I am getting my legend fronts and stock rears powdercoated atm. That will be enough for me for now. In the future I wanna look into getting aluminum calipers and lightweight rotors because that weight is huge in rotational mass.
Just to let everyone know, later this summer I plan on doing something with the rear brakes, I hope to match them rather well with the RL front calipers. And of course, Im aiming for them to be cheaper then the Rotoras.
i want to do this upgrade
i want to make sure i have everything i need.
calipers - 95 legend
rotors - http://www.summitracing.com/parts/PSR-126-40046SR/
brake lines - http://www.tirerack.com/brakes/resul...rand=Goodridge
pads - not sure can someone help me out with suggestions.
is the legend calipers the best choice?
am i missing anything?
Get everything from AJUSA.com. They offer free shipping.
Brake Lines
http://www.ajusa.com/details/Russell...+Line+Kit&vq=&
Brake Rotors
http://www.ajusa.com/details/Power-S...V6;+3.2L;+GAS&
Pads
http://www.ajusa.com/browse/Brake-Pa...&model=CL&go=+
I like EBC pads.
Use coupon code 4DAD at checkout for 10% off.
Brake Lines
Brake Rotors
Pads
I like EBC pads.
ok ppls i already did this mod like 2 yrs ago, it improved braking a lil but in my opinion not much it just reduces rotors warping .
But my question is this, when i did this i just painted it with sm brake caliper paint.
Is it too late to take them out again and powder coat the calipers ?
Whatz the turn around time b4 u get them back ?
ANd how much does it cost to powder coat 1 caliper on average ?
i am thinking maybe powder coating in blck is a lot cheaper bcos i fi was to go thru the rigor of powder coating anything i def want some color (e.g match body color) or red etc but defnatly not black.
I persoanally think black is for hiding smthng (like to make a modified engine look stock in appearance or smthng)
Painting something dsnt mean you cant get it powdercoated. I had my 4 calipers and 4 brackets, 8 pieces total, blasted and powdercoated in a single coat of satin black. Some colors require more coats and costs more. I was gonna do black or body color, but the powdercoater said they cant match body color with the powdercoat well. Since they are stock calipers black is the best option anyway imo. I understand bright colors on bbk calipers tho. I paid 150 total, so divide that by 8 and its 18.75 per piece. As far as turn around i would guess roughly 1 week depending on how urgent you are when talking to them and how much business they have.
Brake Lines
Brake Rotors
Pads
I like EBC pads.
Brake Lines
Brake Rotors
Pads
I like EBC pads.
what do the colors represent?
which do you recommend?
Check out the ebc website and see which pads suit your needs best. I like my Red Stuff pads though.
xsilverhawkx
09-28-2015 06:51 PM
