a/c problem help!!!
Old Aug 18, 2007 | 07:10 PM
RTizzo's Avatar
a/c problem help!!!
recently i notice that my car rocks like a boat while driving. most noticeable 20-40 mph. feels like im tapping the gas and letting go continously. i notice that the rpm jumps about 250 up and goes back down. I took a look under the hood i can hear something clicking on and off- im guessing something with the a/c. This problem only happens when the a/c is on. any ideals?
Old Aug 18, 2007 | 10:19 PM
Blasted69's Avatar
03 Anth Type S 6 Speed
Do you have the under drive crank pulley?
Old Aug 19, 2007 | 03:22 AM
RTizzo's Avatar
my car just has the k&n filter with no resonator. everything is completely stock
Old Aug 19, 2007 | 03:29 AM
BigLizard's Avatar
Moderator Alumnus
Your the guy with 165k+ on your tranny right?
Old Aug 19, 2007 | 12:01 PM
OrngeAc3.2's Avatar
i have the same problem,and im at 94k...i also had a major slip the other day, think my tranny is on life support
Old Aug 19, 2007 | 04:09 PM
RTizzo's Avatar
its not the tranny because why would it only happen when the a/c is on? my car is at 172k but i got tranny replaced at 168
Old Aug 19, 2007 | 11:11 PM
SuperTrooper169's Avatar
In the Mid-South meow
Same problem here. I'm at 89k and had the tranny replaced 10k ago. It's definintely worse with the A/C on, but it does it with the A/C off as well, just not as much on mine. I'm at a loss. I'll let you know what Acura service says about mine when I take it in... unless I trade my CL in before then.
Old Aug 20, 2007 | 01:06 AM
RTizzo's Avatar
btw i first started noticing this after i used this
Old Aug 20, 2007 | 03:28 AM
BigLizard's Avatar
Moderator Alumnus
Sounds like something is loose...I'd check with teh belts, pulleys, and tranny/engine mounts.
Mike Pilipenko
Mar 26, 2024 09:21 PM
SidhuSaaB
May 30, 2020 12:40 AM
12vancover
Oct 16, 2015 12:04 PM
Matthew Purpura
Sep 25, 2015 06:10 PM
MikeJM310
Sep 24, 2015 07:24 PM
