to bypass or not to bypass
g
how important is the bypass for the aem cai? could i really f*** up my engine if i don't get it? i live in chicago and we get a lot of crappy weather(last few winters we got a ton of snow) if that helps.
If you suck a column of water up your intake, your engine is toast. But that should only happen if you drive through a foot or more of standing water. Personally, I'd sleep better knowing I had a bypass just in case.
Originally posted by id:
<STRONG>hrmm....do most people who get the aem cai get the bypass?</STRONG>
[ 08-18-2001: Message edited by: AcurA CrazY ]
Moderator Alumnus
This has only been discussed about a million times - I suggest you use the search engine to read all the arguments for/against it.
Bottom line however is:
No, There is a 99% chance you won't need it.
And in that 1% you can probably get away with it if you are careful not to accelerate in deep water.
However, if you don't get away with it, you will blow up your engine.
Any other minute questions about the bypass you can find by searching. Or click on the link about the bypass valve in my FAQ (link in my sig)
Username 0
2G TSX Performance Parts & Modifications
23
09-28-2015 09:09 AM
frozenpenguins
08-29-2015 12:54 AM
