Bunch of Warning lights.
9.5 lbs o' Boost!!!!
I disconected the battery to do some interior mods... and when I reconnected it my VSA light was on and also m check engine light. My check engine light is on because I need to replace my TPS sensor but why the hell would my VSA light be turned on all of a sudden? anything bad I should worry about or any clue on what it may be and how to fix it. Also Should I buy a TPS sensor and replace it myself as aposed to bringing it to the dealer? The voltage is just reading low. Thanks for the help.
No I never replaced the OPDS in the seats. Ill search how to reset. What about the TPS sensor.. Worth doing my self? I took the airbag out, can that have anything to do with it.
SOLD: 03 SSM CLS Auto
If the OPDS was never replaced, I'd suggest taking the car into a dealer and getting SRS code checked out. If it is in fact the OPDS, it's covered under waranty. Either way, it's $80 to check the code, and you'll have the peace of mind of knowing the what the problem was.
When I saw the VSA light on my CL come on, it was followed by a violent downshift from 5th to 2nd. And a trip in to the dealer for a new tranny once the VSA was on and the CEL was on.
Originally Posted by RaviNJCLs
Why did you remove your airbags?
every time i look at this thread I cant see anything except the first post. The only way I can see it is if I post.. very strange. I just reset my avitar and the old one is still there....
My throttle body sensor is reading low voltage. The dealer wants to change it for 300 installed... waaaaay to much. were can I find one and do it myself?
You can buy a scan tool for that!
The VSA light can come on during all sorts of trouble codes. I have no clue why but it happens frequently. My primary O2 sensor went bad and the CEL, VSA, and ! lights were all on.
![Shrug](https://acurazine.com/forums/images/smilies/shrug.gif)
I'm Cool
Originally Posted by mrsteve
$80 to check a code!?
Thanks steve. I just needed to knoe where to buy one.. the install is the easy part. I alrady had it scanned and the only problem was the TPS sensor was reading low voltage.
SUPRMN84
10-07-2015 09:46 PM
xsilverhawkx
09-28-2015 06:51 PM
