Bubble in Tire Question
Old Jan 6, 2002 | 05:42 PM
Ahmad310's Avatar
I noticed the other day that i had a bubble in one of my Tires. Is this covered by anything? and what should i do about it?
Old Jan 6, 2002 | 06:08 PM
Nicky Pass's Avatar
Fuct in the hed!
Nope, I had a bubble in one of my tires, and the dealer said its not a manufacter's defect.
Old Jan 6, 2002 | 06:11 PM
Kahn Man's Avatar
I had two. One in my 98 RL and one in my CL Not covered by Acura, so when you take it to get it replaced, ask them to show it to you.
If the tire is damaged on the inside, it is not covered by Michelin and means the rim stabbed into the tire as a result of hitting a pothole or a curb. If there is NO damage noticeable inside the tire, then it is a tire defect and covered by Michelin.
That's how it was explained to me by Acura and Bell Tire.
Old Jan 6, 2002 | 07:01 PM
Infamuz's Avatar
Retired Post Whore
Sorry, the bubble is not covered under warranty. You have to buy new tires, which absolutely sucks!
Old Jan 6, 2002 | 07:08 PM
bl^5's Avatar
Got da Internet Goin Nutz
Bubble in the tire club
I beleive that the bubble in the tire club is very close to the scratched rim club in number. Something about these michelines beg for the bubbles. There is nothing you can do about it except buy new tires. I too have a bubble and when I buy my next new car I am going to look into buying a road hazard warranty form someone before I drive it off of the lot. I don't know if this is possible, but I will definately look into it.
Old Jan 6, 2002 | 09:34 PM
Eggplant-EX's Avatar
I believe that tire shops (Les Schwab) will sell a warranty for the tires.
Not worth it in my opinion. Why pay for the warranty? Save the cash and if you do have problems, then use that money to buy a new tire.
Old Jan 6, 2002 | 09:56 PM
monkeymato's Avatar
Buckle Up
Get a new tire asap. If it happens to blow your screwed. My bros tire bubbled...we looked for a warrenty but theres none. Just buy 2 new tires.
Old Jan 7, 2002 | 12:15 AM
friendlydacat's Avatar
Unemployed BUM
The Michelin dealer gave me a deal on the new Yokohama 420's, which is similar to the Michelins. The tires normally costs $100.00 but the MIchelin dealer adjusted the price to $35.00. The only problem is I have mismatched tires. As soon as I find employment, they will match again.
Old Jan 7, 2002 | 08:01 AM
bl^5's Avatar
HMMM $10 for a waranty that will get you a new tire or $150+ for a new tire.
Worth it!
Old Jan 7, 2002 | 10:59 AM
MikeS 18's Avatar
Adult Supervision
Bubble in tire? been there, done that.
Old Jan 7, 2002 | 12:20 PM
moomaster_99's Avatar
From: Somewhere between here and there, yet neither.
Worth it!
Just a note for you guys. If you get a nail in your tire with a road hazard warranty, they need to tell you that you have now lost one speed rating and, they don't mention this, but you are entitled to a brand new tire if it has a V?Z? rating or higher...whatever the speed rating is on our Michelins.
Old Jan 7, 2002 | 01:24 PM
proactive's Avatar
I've had to have all 4 of my tires replaced in the span of 45,000 miles. 1 had a bubble, 2 blowouts, and 1 with dangerous tread ware. The tread ware is supposed to be 40,000 miles, so I guess I did all right. These goddamn things are way to fuckin' expensive, $200 each. I think it's a design flaw on the part of Acura - aren't there better tires you can get for cheaper? I'd be satisfied if our stock tires where the absolute best you could get for the price - but with all the problems I've had, I have a hard time believing that.
The tire place said that there was a type of Eagles (or something) that would fit, and they were about $40 less, I'll have to look into that for the next time. He said they would be more performance oriented.
Old Jan 7, 2002 | 01:36 PM
bl^5's Avatar
The only bad thing about replacement tires is the length of time they will last. I tend to drive a lot thus, I usually replace tires often. The downside of the 17" tires is that most are high speed rated and thus do not last very long. The good side is that they feel better and give better performance. I am about to get a set of Kuhmo 235/45/17. They only cost $100 a peice which is the best price I could find. If you paid $200 for each of yours, I am sure that 2 sets of Kuhmo's should last as long as one set of the michelines and you will get a better ride in the process.
Old Jan 7, 2002 | 01:43 PM
proactive's Avatar
Kuhmo 235/45/17
Hm, thanks for the tip. How are they in the snow and rain?
Old Jan 7, 2002 | 05:43 PM
Nitin's Avatar
But I just got here
This exact question has been asked so many times already, that it's probably worth a spot in the FAQ. The problem isn't covered under any warranty, and the tire should be replaced immediately because of the greater probability of a blowout.
Old Jan 7, 2002 | 07:33 PM
acura_service's Avatar
www.drippinwet.com
this is common with low profile tires, i've seen it alot, esp on pirelli p7000 supersports - it usually happens from a point of impact, pothole usually - the steel cord splits causing air pressure from within to push out on a secondary layer of rubber behind the outer skin - very dangerous - get a new tire imediately
BobbyGraham388
Oct 22, 2015 05:05 PM
datadr
Sep 12, 2015 09:12 PM
datadr
Sep 2, 2015 06:46 PM
bailey24
Aug 31, 2015 05:38 PM
