Broken Header Stud
Old Nov 10, 2006 | 11:49 AM
Blitz's Avatar
Recently turned 18
Broken Header Stud
How bad would it be to run with one snapped off (temporarily of course)? Easy fix or PITA?
I thought there was a thread from the stone age where someone broke one off, but I can't find it.
Old Nov 10, 2006 | 12:29 PM
RaviNJCLs's Avatar
If you are talking about the actual header stud and not the heat shield, I would get it fixed as soon as you can. It can cause leaks.
Old Nov 10, 2006 | 12:57 PM
gc86's Avatar
Advance
It'll run, but like Ravin said, get it fixed ASAP. You might hear some extra noises too
Old Nov 10, 2006 | 06:21 PM
Blitz's Avatar
Recently turned 18
Yeah, I need to. Hoping it's a DIY kinda deal. Guess I'll see when I pull the headers off again. Otherwise someobody will be paid for a mistake. I found some "advice" if you can call it that over on the 2GTL side. We'll see what else I can break while trying to fix one problem.
Old Nov 14, 2006 | 09:43 PM
1qikacura's Avatar
how would you remove the broken bolt once you remove the headers? what tool would i need?
Old Nov 15, 2006 | 09:47 AM
SuperTrooper169's Avatar
In the Mid-South meow
I'm just taking a guess on this one, but maybe try backing two bolts up onto each other and crank the stud out. I'm assuming it just screws into the head.
Old Nov 15, 2006 | 11:59 AM
Jared03CLS's Avatar
Luckiest Man on Earth.
Drill it out and re-thread the head?
Old Nov 15, 2006 | 12:11 PM
Final's Avatar
Opium den in
Have someone do it if you dont know what your doing ... safest way to go but if youre tight on money just be careful with your car
Old Nov 15, 2006 | 12:56 PM
All Mine's Avatar
I'm a Vagiterian.
Get a dremel with a really small cutting head, and drill an X or a I in it, and try to back it out. That way you don't have to make a new thread in the block.
Old Nov 15, 2006 | 11:23 PM
1qikacura's Avatar
about how much do you guys think will a avg shop charge me to do this process?
Jul 16, 2017 07:33 AM
CL-S progression 01
Jan 26, 2016 04:15 PM
gatrhumpy
19
Dec 31, 2015 04:22 PM
juanrl
Sep 29, 2015 03:25 AM
