broken end link mount?? AGAIN??
Old Nov 27, 2010 | 11:10 AM
CL-S progression 01's Avatar
lowrd on tein CS biatch
K so last year I had the same thing happen. Where the rear sway bar mounts to the suspension it's a 20$ bracket.... well today I swapped on my winters and i think it was soo weak that in the process of jacking on side up i heard a sound. and found the end link ripped through the bracket again.
I heard a few knocks in the suspension but thought nothing of it. but now I know why..
so I ordered 2 for the broken side and one for the side that's still OK.
But I wanna know why this is happening?
when I switch to coilovers I think the drop will decrease all the sway the bar needs to handle and save the mounts from tearing out again... but for now.
I have ordered the brackets again and will replace on monday when I get them and then adjust the bar to the softer setting (whereas now it's on the stiffest setting).
Any thoughts fellas?
am I the only one?
Old Nov 27, 2010 | 12:14 PM
whiteknight's Avatar
Are you talking about the sway bar link? I have had a couple of those go and the dealer indicated there were some lots with bad welds.
Old Nov 27, 2010 | 02:24 PM
rp_guy's Avatar
'03 ABP YA4-S 6MT
yes you are the only one
https://acurazine.com/forums/showthr...d+link+bracket
Old Nov 27, 2010 | 03:07 PM
wellll it looks like I need to buy a set of new ones and get them REINFORCED then!!! since this is just going to keep on happening as it seems.
I will post the results when The new ones from acura are reienforced...
going to out a huge metal sleeve around the top of the bracket where it RIPS out to gain some rigidity so it doesn't just shear right off for the 3rd time.
both times it was the passenger side.... weird.
awww well suspension is being FULLY re-do come spring so these are just the icing on the cake.
marcelft
Jul 10, 2018 06:17 PM
Onyxthecat
Oct 18, 2016 02:05 PM
BKSleeper
Oct 7, 2015 10:20 AM
DiamondJoeQuimby
Sep 10, 2015 11:40 AM
RK_AcuraTL
Sep 5, 2015 02:26 AM
