brake question
Old Jan 27, 2003 | 09:18 AM
ALoP's Avatar
got rocks??
brake question
sup guys - i had a brake question. I recently replaced the pads on my wifes car (calideserttulip). And at first the pads were sticking something fierce. So I bled the brakes to no avail. Then i remembered the nut that goes inbetween caliper bolt and the caliper...seems when i took the pads off originally this had spun or tightened down allowing the caliper bolts to tighten further and further....i spun the bolt back out and think i got it...question is (dont have a manual) does this nut need any adjustment? Is all the way out okay or is there a specific length it needs to be adjusted in?
Also after changing the pads the car still shakes side to side when braking..I remember reading about a recall (here i believe) that i thought was reffering to the pads..problem persists. Possible the recall was for rotors??
kj this ones great heh heh
Old Jan 27, 2003 | 01:23 PM
ALoP's Avatar
got rocks??
ttmft
Old Jan 27, 2003 | 01:41 PM
CO-CL-S's Avatar
There is a TSB 01-017 for the front pads to be replaced. The rotors will be turned (if within spec., replaced if not).
Old Jan 27, 2003 | 01:56 PM
Sly Raskal's Avatar
if the car shakes side to side when braking there is definatly a problem with the rotor's. Usually that happens because the rotor's are warped. I doubt that's because of a defective rotor, usually that happens because of wear and tear and hard braking. i've noticed this happening more on my car (CL-S), guess i'm still used to my integra with upgraded brakes, that thing could stop on a dime.
I don't know about the nut on the caliper though. you should talk to a mechanic about that one.
Old Jan 27, 2003 | 02:56 PM
CO-CL-S's Avatar
This is for your wifes car? This one?? Another game player....
Originally posted by calideserttulip
Im a broke ass business owner. My 2001 Gold Baby is in desperate need of attention. Is there anyone out there that can hook me up with some stuffs (free or half the cost of the dealer):
Need new tires lock
Need rear tires
Need Oil change
Need brake change
Need a new paint job on my left door (some idiot decided to fall asleep behind the wheel and slam into my left side and run)
Need a 45k maintenance
Just a cali-desert-tulip (the one and only)
Old Jan 27, 2003 | 03:02 PM
ALoP's Avatar
got rocks??
yup thats hers...thanks for the info on the rotors. I was out working and started to think the same. The rotors have got to be warped...hope there not 100 bucks a pce. Shit rotors for my jeep are 25 a pce...crossing fingers.
I know there was drama when she tried to post here...im not gonna defend her (as she did a bit of trolling i suppose) but I would say a few of you were a bit harsh.
anyone know the going price for rotors vs. getting them turned?
Old Jan 27, 2003 | 03:44 PM
ALoP's Avatar
got rocks??
is the tsb number enough to get it done? Take it to the dealer and ask them to perform TSB 01-017?? Think they will trip now that ive replaced the pads?
Old Jan 27, 2003 | 06:48 PM
moomaster_99's Avatar
From: Somewhere between here and there, yet neither.
Aftermarket rotors are about $70 a set. Turning them would cost about the same, since you dont have access to a shop.
mada51589
Jan 9, 2025 04:40 PM
pstomps
Feb 20, 2017 03:29 AM
datadr
Sep 12, 2015 09:12 PM
HOWELLiNC
Sep 10, 2015 01:39 PM
