brake question
brake question
sup guys - i had a brake question. I recently replaced the pads on my wifes car (calideserttulip). And at first the pads were sticking something fierce. So I bled the brakes to no avail. Then i remembered the nut that goes inbetween caliper bolt and the caliper...seems when i took the pads off originally this had spun or tightened down allowing the caliper bolts to tighten further and further....i spun the bolt back out and think i got it...question is (dont have a manual) does this nut need any adjustment? Is all the way out okay or is there a specific length it needs to be adjusted in?
Also after changing the pads the car still shakes side to side when braking..I remember reading about a recall (here i believe) that i thought was reffering to the pads..problem persists. Possible the recall was for rotors??
kj
this ones great heh heh
kj
if the car shakes side to side when braking there is definatly a problem with the rotor's. Usually that happens because the rotor's are warped. I doubt that's because of a defective rotor, usually that happens because of wear and tear and hard braking. i've noticed this happening more on my car (CL-S), guess i'm still used to my integra with upgraded brakes, that thing could stop on a dime.
I don't know about the nut on the caliper though. you should talk to a mechanic about that one.
This is for your wifes car? This one?? Another game player....
Originally posted by calideserttulip
Im a broke ass business owner. My 2001 Gold Baby is in desperate need of attention. Is there anyone out there that can hook me up with some stuffs (free or half the cost of the dealer):
Need new tires lock
Need rear tires
Need Oil change
Need brake change
Need a new paint job on my left door (some idiot decided to fall asleep behind the wheel and slam into my left side and run)
Need a 45k maintenance
Just a cali-desert-tulip (the one and only)
Need new tires lock
Need rear tires
Need Oil change
Need brake change
I know there was drama when she tried to post here...im not gonna defend her (as she did a bit of trolling i suppose) but I would say a few of you were a bit harsh.
anyone know the going price for rotors vs. getting them turned?
There is a TSB 01-017 for the front pads to be replaced. The rotors will be turned (if within spec., replaced if not).
mada51589
Jan 9, 2025 04:40 PM
