brake fade & tranny problems
5th Gear
after months of looking at Lexus, BMW & other cars similar, I decided to buy a 2001CLtype S. Much to my suprise, wow tranny problems & brake pulsating.
In that the car only has 20K miles, what other suprises may I encounter. Is there any suggestions from other CL owners
my rotors were replaced @ 4k miles and there are tons of "slushbox" owners' threads to be read...do a search or go back to the "transmission" board... good luck
Moderator Alumnus
Ya, you have found the 2 big ones. Otherwise here's the others...
rear deck rattles (usually people with sub woofers)
moon roof rattle (very common)
dash rattles (usually temperature related, cold no rattles, warm lots of rattles)
squeaky seat
paint chips easy (bad paint in general)
Wheels scratch easy (wheel protrudes out further than the tire)
stereo has no bass
2nd stage intake actuator go out
cheezy stock tires
windows make noise going down
right exhaust pipe hangs lower than left
spoiler rattles (usually only people with sub woofers)
leather in seats cracks, or has hairs coming out
Seat belt doesn't retract 100% smacks again side of car whenyou get out
That's about it... I'm sure someone else can chime in with any I missed.
Most of them can be fixed. Wheels/paint... well... you just have to live with it.
Those are the most mentioned problems. I'm sure others have little things here and there.
squeaky seat
stereo has no bass
cheezy stock tires
BUT...every make and model car has issues of some sort.
Don't let these issues influence your perception of the car. The tranny warranty goes to 100k miles and everything else (for the most part) is covered for 4yrs 50k miles. The brakes just need to be upgraded.
rear deck rattles (usually people with sub woofers) i removed 3rd brakelight, installed foam padding
moon roof rattle (very common) removed headliner, fixed rattle from drip tray
dash rattles (usually temperature related, cold no rattles, warm lots of rattles) the post it/ pen holder thing rattles
squeaky seat
paint chips easy (bad paint in general) not that bad imo. rocks will hammer any paint job
Wheels scratch easy (wheel protrudes out further than the tire) if you know how to drive a nice car it's no problem
stereo has no bass
2nd stage intake actuator go out not yet
cheezy stock tires
windows make noise going down window regulator on order
right exhaust pipe hangs lower than left i adjusted the hangers
spoiler rattles (usually only people with sub woofers) :swear2:
leather in seats cracks, or has hairs coming out hairs
Seat belt doesn't retract 100% smacks again side of car whenyou get out :o
squeaky seat
stereo has no bass
cheezy stock tires
i also have a windshield on order. i complained about the trim curling up and i guess the trim is 1 piece w/ the windshield so the best fix is to replace the whole thing.
i still love the car. it's like brand new, all the parts are new.
You are not having brake fade. Your car has warped rotors, caused by uneven cooling of the rotors.
They can be resurfaced, but will likely just warp again. This is a problem very common on many different types of cars. Use a quality rotor to avoid it in the future. My BMW that sees track time with aggressive track pads and tires has cryo-treated and slotted Brembos. No fade or warping. But, for street use, you only need a good rotor. Likely means non-OEM, as those seem to warp easily...
mada51589
05-03-2022 08:54 PM
HeloDown
09-08-2015 06:51 PM
