Bottle Heater & Purge Installed...Going to the track tomorrow!!
Old 04-28-2004, 09:15 AM
  #81
horny =
bent09's Avatar
and a car cut me off going about 85 and I hit both guard rails.
Old 05-04-2004, 11:50 PM
  #82
Sold 12/29/04 :-(
SFLA_Type-S's Avatar
Originally posted by scalbert
http://www.wbo2.com
The fuel pressure gauge isn't a bad idea when doing what you are.
As for what A/F ratio, go for lower than 12.0:1; 11.5:1 will be safe.
Hey Scalbert, I just installed my Comptech fuel pump & will be changing my plugs this weekend. I also plan on installing a MSD DIS-4 ignition to retard the timing 4 degrees.
The last thing I need is the TechEdge wideband unit. I went to this page http://www.wbo2.com/orderpage.htm but I am not sure what I need to order (there are so many choices). Can you point me in the right direction?
Old 05-05-2004, 06:22 AM
  #83
scalbert's Avatar
AU$535
4.0 m WBo2 (2.0) system (for 7057)
System for 7 057 sensor but does not include the 7057 sensor
To order the sensor click on the link midway down:
http://www.wbo2.com
Old 05-05-2004, 10:53 PM
  #84
Sold 12/29/04 :-(
Thanks again scalbert
Old 05-05-2004, 11:10 PM
  #85
Sold 12/29/04 :-(
...includes LD01 display & either 2.6 m or 4.0 m cable with 7057 connector.
Do I need the 2.6m or the 4.0m cable?
Old 05-05-2004, 11:30 PM
  #86
mattg's Avatar
did you get the blow down installed?
Old 05-06-2004, 12:08 AM
  #87
Sold 12/29/04 :-(
Not yet, I want to get the car running right again before I do the blow down tube. Did you install yours yet?
Old 05-06-2004, 03:01 AM
  #88
mattg's Avatar
i just finished emptying the bottle. i'll do it this weekend.
how was the fuel pump install? are you using zex plugs again?
Old 05-06-2004, 06:22 AM
  #89
scalbert's Avatar
The 2.6M cable should be fine as I have plenty of excess.
Old 05-06-2004, 07:20 PM
  #90
Sold 12/29/04 :-(
Fuel pump install was pretty easy. It took me about an hour because it was my first time. I could probably do it in half the time if I had to do it again. It was an in-tank pump & you can access the fuel pump from the trunk. You don't need to jack up the car or anything.
Yes I am using Zex plugs again. I'm just changing them because I have been running the same plugs since I first put in the Zex kit (two years ago). I think they've had it by now.
  #91
Sold 12/29/04 :-(
Thanks scalbert.
Old 05-06-2004, 07:21 PM
  #92
Sold 12/29/04 :-(
Thanks scalbert.
Old 05-06-2004, 07:59 PM
  #93
mattg's Avatar
my stock plugs are at 50k. they still seem to be working fine though.
Old 05-06-2004, 08:20 PM
  #94
Sold 12/29/04 :-(
Matt, please tell me you are not running stock plugs with nitrous. That is a big
Old 05-06-2004, 09:00 PM
  #95
mattg's Avatar
yep, stock plugs. i didn't know new plugs were manditory.
Old 05-08-2004, 09:24 PM
  #96
Sold 12/29/04 :-(
http://www.zex.com/Technical/Help/NitrousOxide.asp
Do I need to use different spark plugs when using the ZEX nitrous kit?
It is highly recommended that you install non-projected nose style spark plugs that are 2 heat ranges cooler than stock plugs. For best results, use our Hyperformance triple electrode spark plugs . These spark plugs were designed specifically for nitrous, turbo, and supercharged applications.
Matt, please change your plugs ASAP unless you want to damage your car!!!
Old 05-08-2004, 09:30 PM
  #97
Sold 12/29/04 :-(
Spark Plugs and Nitrous Oxide:
What Works, What Doesn't, and Why
Over the years there seems to have been a great amount of technical material written about the simple operation of a spark plug and what they can do in relation to the way an engine runs. There are a few basic characteristics about spark plugs that you need to know to make an intelligent choice about the correct spark plug for your application.
First, and most important; a spark plug must be of the correct design to operate within the environment of your engine, not the other way around. This means that the spark plug has virtually no influence on how the engine burns fuel or runs in general. The correct spark plug will simply survive the conditions present in your engine. A spark plug must maintain a certain temperature to keep itself clean. The wrong heat range can cause an overheated plug or a fouled plug. The heat range refers to the temperature of the ceramic material surrounding the center electrode.
Lean air/fuel ratios are more difficult to light because there are less fuel molecules in the area of the plug gap when the plug is scheduled to fire; thus, projected nose plugs were designed for late-model lean-burn engines. Modern high-energy ignition also allowed larger plug gaps. All the while this was happening, something else happened. Something that no one seems to have really noticed as the real culprit when the issue of factory type plugs being used with nitrous comes up. We'd like to clue you in.
Quite often, a factory type, wide-gap projected plug will produce a misfire condition after only a few seconds of nitrous use. The misfire is not due to the heat range. The misfire occurs because the ground strap of the spark plug becomes a glowing ember because it is too long to dissipate the extra heat produced by a nitrous-accelerated burn condition. The correct fix for this phenomenon is to replace the plugs with one that has a shorter ground strap. By doing this, you will shorten the path for the heat being absorbed by the ground strap. You can use the same heat range, you just have to find a non-projected nose plus with a shorter and preferably thicker ground strap.
If you only change the heat range of the spark plug to a colder heat range, you may very well still have the misfire problem. Since the length of the ground strap is the cause of the misfire, a colder spark plug may have the same length of ground strap as the hotter plug you replaced it with.
Spark plug gaps should generally be .030" to .035". Never try to gap a plug designed for an .060" gap down to .035". Find the correct non-projected nose plug designed for an .035" gap.
Old 05-08-2004, 10:43 PM
  #98
mattg's Avatar
i guess i better get some plugs. :o
Old 05-09-2004, 12:14 AM
  #99
///M POWER
darrinb's Avatar
they are only like 30 bucks...
Old 05-09-2004, 09:37 PM
  #100
Sold 12/29/04 :-(
I just changed mine today. You're going to have lots of fun with the three plugs in the rear.
Old 05-10-2004, 05:11 AM
  #101
scalbert's Avatar
IMO, they aren't that hard. In fact, besides the I4 engines I have owned, this car is the easiest in base form. The GTP, with it's pushrod engine, has the plugs between the exhaust ports so they are lower and harder to get to than the rear ones on the CL-S.
That still wasn't as bad as my Typhoon with a plug behind the steering shaft.
However, add the SC to your car and you know have a problem changing the front plugs on the CL-S
Old 05-10-2004, 01:01 PM
  #102
Moderator Alumnus
mantis23's Avatar
i've changed 2 times so far. both iridium IK20s.
darrinb, you said 30 bucks for plugs? where can I get this deal?
I paid ~$65 the first time, and $45.00 the second time(private seller). where can I find plugs for $30.00?
mattg, are you still on your first transmission?
Old 05-10-2004, 02:02 PM
  #103
mattg's Avatar
nope. i'm on #2.
Old 05-10-2004, 02:45 PM
  #104
///M POWER
darrinb's Avatar
mantis, i think the zex plugs are like $30, check zex's site
Old 05-10-2004, 02:52 PM
  #105
mattg's Avatar
shit, darrin is right.
should i get the zex plugs?
http://www.mmrusa.com/zexplugs.htm
Old 05-10-2004, 03:02 PM
  #106
Moderator Alumnus
mantis23's Avatar
hmm, i've never used them or read a review on them before. Ask around and see if others have tried those plugs.
Old 05-10-2004, 05:00 PM
  #107
Sold 12/29/04 :-(
Matt, I have been using the Zex plugs since I put in the nitrous. I have no complaints.
Old 05-10-2004, 07:22 PM
  #108
ModAddict's Avatar
After 3 or four times,... it get's easier. :sqnteek:
Old 05-10-2004, 11:01 PM
  #109
///M POWER
darrinb's Avatar
when am i not :P
Biggie_B
02-26-2017 11:14 AM
Jimmy_D
10-07-2015 11:52 PM
07Acuradude
09-29-2015 03:01 PM
Quick Reply: Bottle Heater & Purge Installed...Going to the track tomorrow!!
