Blinking Maint Req'd is...???
Liq, how many miles do you have? I think the maint light lets you know when u need to do one of those scheduled maintenance like the Type, 2,3,4
Maintenance
Maintenance
7th Gear
It depends on the miles...check the owner's manual it will tell you what is needed.
to reset the maint light put key in the ignition press and hold the select and reset buttons turn the key to the acc. mode( you don't have to start the car) the maint light will flash a few times then shut off. continue to press the buttons turn the ignition key off, then let go of the the buttons.
ripit
09-26-2015 06:19 PM
