basic newbie ebrake question
Old Jul 13, 2003 | 06:15 PM
Guru's Avatar
AKA MaxGeek
if i park on a steep hill (my driveway) put the car in neutral and put the eBrake on, should my ebrake be strong enough to stop the car? My car just rolls all the way down the hill.
Old Jul 13, 2003 | 07:12 PM
zigzagzig's Avatar
hahahahah it rolls all the way down the hill? then obviously the ebrake isn't strong enough for that hill ahhaha
Old Jul 13, 2003 | 07:18 PM
NSX-Tuner's Avatar
boosted is best
Re: basic newbie ebrake question
If adjusted correctly, it should hold even on steep hills.
Old Jul 13, 2003 | 09:56 PM
mt6forlife's Avatar
The ebrake should be strong enough to hold the car, but the cable stretches and it gets less effective over time. Set the ebrake, put it in neutral, release the brake pedal and let the car roll back till the ebrake stops it. Then put it in park. That will keep pressure off the tranny's parking gear. If when you go to leave, its a little hard to get the car out of park, its because its rolled a little until the tranny stopped it. Get the ebrake tightened then.
Old Jul 13, 2003 | 11:12 PM
dfv3.2CL-S's Avatar
Best thing go to the dealer and have them adjust the dam E brake, other than that you will have the whole weight of the car resting on the gear of your choice. Not a goood thing to do on manual transmission because with time it will damage the gear.
Old Jul 14, 2003 | 12:48 AM
civic4982's Avatar
SHIFT_over.so.I.can.see
yeah, just get them to adjust it. I had mine done. It should only click from 7-11 times before completely stopping the car. It should be under warranty.
Old Jul 14, 2003 | 01:56 AM
Guru's Avatar
AKA MaxGeek
Thanx I'll take it in
Old Jul 14, 2003 | 05:08 AM
bullaculla's Avatar
He has an auto
06TLMatt
Oct 2, 2015 08:14 PM
Strath
Sep 27, 2015 11:53 PM
Rachel Lu
Sep 27, 2015 09:53 AM
atsx1313
Sep 22, 2015 09:04 PM
datadr
Sep 12, 2015 09:12 PM
