Basic Amp Question
Old Jan 27, 2003 | 08:09 PM
ACsocr9's Avatar
Basic Amp Question
How many amps should I have running with 2 10" JL subs? Thanks fellas. Lata
Old Jan 27, 2003 | 08:26 PM
AcurajL's Avatar
I hand out swivel heads
That is not enough info. What series subs are you using? Than I can help you.
Old Jan 27, 2003 | 08:43 PM
monkeymato's Avatar
Buckle Up
If you have 2 10" JL w6 (i think) then if your running a 500/1 JL Audio amp you should be fine but Acurajl knows alot more then me. He'll give you better info.
Old Jan 27, 2003 | 10:35 PM
Sly Raskal's Avatar
depending on the size of the sub, the enclosure as well as what the "rms" rating is on the subs you should base your answer.
you want to go for an amp that can at least deliver how much power the sub would operate at rms. that will allow your sub to basically operate at peak performance without sacrificing distortion. if you put too much power in you may blow the sub and cause distoration, put too little power and you won't hear too much and when you turn it up it'll distort. so if you shoot for the rms rating of the sub, you'll definetly have a good system.
Old Jan 28, 2003 | 11:06 AM
AcurajL's Avatar
bump...what kind of series subs?
Old Jan 28, 2003 | 11:14 AM
Sly Raskal's Avatar
JL has a chart on their website documenting how much minimum power and maximum power you should pump into their subs,
notice how they mention rms power just like i mentioned above in my previous post
the chart is at
http://www.jlaudio.com/subwoofers/RP_Chart.html
if the chart is hard to see, you can download a high res version here:
http://www.jlaudio.com/subwoofers/pd...PowerRange.pdf
jpadilla
3G RLX (2013+)
Nov 18, 2017 07:13 PM
Strath
Sep 27, 2015 11:53 PM
Medinak12
Sep 23, 2015 07:11 PM
Pegon95
Sep 15, 2015 01:54 PM
datadr
Sep 12, 2015 09:12 PM
