axxis ultimate pads
Old Jun 20, 2006 | 10:39 PM
rsprattmann's Avatar
Cool axxis ultimate pads
How many miles should I expect to get out of these pads(axxis ultimates)? Im using rotora slotted disc. The front pads seem to be about 40 to 45% at about 30,000. Only noticed pad wear due to brake fluid light coming on on steep hills. No fluid leaks, had to fill due to pad wear. The rear pads seem like 75% is still left. So is this premature wear? I think about 20,000 might be left on them. Original equip pad lasted over 80,000 with pad left, but were changed out due to new pad / rotor resurface recall.
Note: These axxis ultimate pads have good stopping power, no squeaks, but high dust.
Any suguestions for future pad brand that has less dust but same stopping power and is quiet?
later
Old Jun 21, 2006 | 11:13 PM
toledo_type_s's Avatar
6th Gear
I use Axxis metal masters on my 300zx and am very happy with them. They have built in shims, create very little dust, have good stopping power, and are very quiet. Just make sure you use the nasty anti-squeal compound on the back of the shims and they won't squeak one bit. These are popular in the 300zx community and will hold up for quite awhile. I am sure they would work great on a CL as well.
http://www.buybrakes.com/store/45-07870M
Cheers,
toledo_s_type
Old Jun 22, 2006 | 02:42 AM
implicit's Avatar
eh
Cheers,
toledo_s_type
Noticable improvement in stopping power over stock pads?
Old Jun 22, 2006 | 03:13 AM
AcuraTLSFan's Avatar
Registered Member
No squeaks yet. I had the rotra/ultimate combo. At first they seem to be perfect. After awhile you start hearing the squeaks....mostly when the brakes are cold. The stopping power is great but the noise isnt'...so I replaced them with Akibono...they are better then OEM but not as good as the ultimates. No dust and no noise...but I do miss the stoping power
Old Jun 22, 2006 | 12:55 PM
6th Gear
Definitely an improvement from stock pads on the 300zx, especially after they heat up. I have slotted cryo treated rotors on the front and x-drilled on the rear and the Axxis MM padswork and feel great.
08_UA7_Gr33k
Feb 11, 2016 02:17 PM
LogicWavelength
3G TL Photograph Gallery
33
Nov 1, 2015 09:38 AM
detailersdomain
Wash & Wax
Oct 9, 2015 10:13 PM
08_UA7_Gr33k
Sep 27, 2015 01:56 PM
2ManyHobbies
Sep 24, 2015 09:23 PM
