AWD to RWD Possible?
Old Nov 5, 2002 | 01:55 PM
Juker008's Avatar
TRELOS
My question is with AWD is it possible to intall an aftermarket tansmission box (<-whats the actual name if it called) that would alow onwers to switch from 4x4 to RWD, or is that only exclusive to 4x4 trucks? Now if it isn't posible to install such a thing than is it possible to disconect the front wheels and be RWD w/o the computer not accept such a thing?
Juker008
Old Nov 5, 2002 | 02:00 PM
scalbert's Avatar
Actually you can, in some applications, just remove the front prop shaft. I snapped mine in my old Typhoon and had to drive around in RWD mode for two weeks. That was fun and scary at the same time.
Old Nov 5, 2002 | 02:58 PM
Zoot's Avatar
__
then why doesn't jag turn the fwd made to awd x-type to rwd?
EDIT: what i wrote above makes no sense. sorry... What I am trying to say is the X-Type was originally FWD, but it was made AWD. Now that it is AWD, couldn't they convert it to RWD?
Old Nov 5, 2002 | 03:35 PM
SiGGy's Avatar
Moderator Alumnus
The transfer case is what your talking about. And yes, it is possible you could find one that allows you to switch. Depends on the application... Making it fit might be another issue...
Also depends if the xfer case is built into the tranny... who knows... If so... then your hosed
Old Nov 6, 2002 | 01:06 PM
moomaster_99's Avatar
From: Somewhere between here and there, yet neither.
It depends on how the car is originially designed. The Jag tranny on the X-type is a FWD converted to AWD, by adding a driveshaft and differentials. The way the engine is mounted plays a large part in determining FWD and RWD as well.
Old Nov 6, 2002 | 04:06 PM
hemants's Avatar
Depending on the system you could just by really slippery front tires so that it would be RWD dominant LOL.
But why would you want to?
Old Nov 6, 2002 | 08:20 PM
Chief F1 Fan's Avatar
It's simple, just use R for forward, and D for reverse and you're all set!!
Old Nov 8, 2002 | 04:41 PM
Juker008's Avatar
TRELOS
HAAAAAAAAAAAAA
Juker008
Old Nov 8, 2002 | 04:42 PM
Juker008's Avatar
TRELOS
Now if the '04 CLS is made AWD then the engine would not be transversed, correct?
Juker008
Old Nov 8, 2002 | 06:29 PM
SiGGy's Avatar
Moderator Alumnus
Juker008
Nope...
Look at the Mitsubishi 3000gt VR4
Old Nov 8, 2002 | 09:20 PM
Juker008's Avatar
TRELOS
Originally posted by SiGGy
Nope...
Sry I have not seen one but I would take it that that 'is' transversed?
Question...why?
Juker008
joflewbyu2
Aug 18, 2019 10:38 PM
copmagnet82
4G TL Problems & Fixes
Jun 29, 2016 08:09 AM
AJRozsa
Oct 5, 2015 07:50 PM
c1souk
Sep 28, 2015 11:20 AM
saturno_v
Sep 27, 2015 08:13 AM
