Auto UP/Down Window Switch
Try resetting it...
From: https://acurazine.com/forums/showthr...=window+switch
Originally Posted by fuzzy02CLS
Only the 03 has auto down & up. Press the window switch all the way down, then hold the switch down for 3 secounds then hold it all the way back up. That's the reset sequence. It should work after that.
Yeah, I made sure to put that in the quote... It's an 03 drivers side only thing, so it's important that its' mentioned... Don't want to make you 01 and 02 guys crazy
Originally Posted by ital_gsr
works fine now thanks for the info
I had a issue with my auto down on the passenger side rear view mirror, and had to disconnect the battery to reset that...
Don't Mess With Texas
my auto down on my 01 is retarded. it will go like almost half way down then it stops...then you press it again and it goes about half that distance and stops...then again and it will finally go all the way.
weird cause it only does it sometimes.
I'm Cool
i wonder if we could buy another auto up/down module and replace them with the passenger window button and make it auto up/down. Anyone tried that yet?
I'm a Vagiterian.
No, but that sounds like a spectacular idea.
I thought i heard some where that it's in the relay or something like that, and not just the switch?
Only my passenger mirror goes Auto Down... wish I could get the drivers to go too, but it doesn't bother me enough to pay to get it fixed... it goes down fine if I am manually pushing the down button, but doesn't go down when I go in reverse... anyone else have this?
White as night.
Ok, so the auto down feature is that your passenger mirror goes down when in Reverse? I figured that might be the case, but wasn't sure... I've been in other cars where they both go down. Just got my car not long ago. Thanks though!
Missing My CL-S
anyone know why its doing this?
i spoke too soon. the reset fixed it for a day. after posting today about it working, i went out this afternoon and it was messed up again
do you have an alarm with the window module. i do and this problem only started once i had them installed.
mine goes down fine w/ the auto, but going back up is my problem. it comes back down a couple inches by itself
i'm going to try the reset again and
i have no idea why let me know what you do/try.
detailersdomain
Wash & Wax
10-09-2015 10:13 PM
