auto roll up and down window accesary
Old Mar 9, 2004 | 10:13 AM
UNCTYPE-S's Avatar
Above n Beyond
ya know where, when u lock the car the windows roll up by themselves or roll down. does anyone know if i can add that onto my stock keyless entry system or do i have to buy an aftermarket alarm system..
thanks
i have an 03 cl-s
Old Mar 9, 2004 | 11:09 AM
UNCTYPE-S's Avatar
Above n Beyond
this is what im referring to.
can i use this if i dont have an aftermarket alarm?
http://www.drdetailshop.com/530T.htm
Old Mar 9, 2004 | 04:33 PM
vinarnold's Avatar
i dont know...
Old Mar 10, 2004 | 09:08 AM
UNCTYPE-S's Avatar
Above n Beyond
bump........nobody knows if this works with the factory keyless alarm system we have.
Old Mar 10, 2004 | 09:28 AM
NSXNEXT's Avatar
NO. That is the DEI window module. It will only work with an aftermarket alarm. I know it works with Clifford, DEI, Viper, not sure how hard it would be to get it to work with another alarm.
Old Mar 10, 2004 | 10:29 AM
UNCTYPE-S's Avatar
Above n Beyond
it doesnt even have to be that exact one i linked, maybe another one can hook up to your stock alarm/keyless entry?
Old Mar 10, 2004 | 10:49 AM
peiqinglong's Avatar
You could prolly try the Lex GS module since that hooks up to a stock alarm system. But I don't know any system that can hook up to the stock for sure.
Old Mar 10, 2004 | 11:01 AM
UNCTYPE-S's Avatar
Above n Beyond
but see i dont know if anyone caught this or not, this module allows the windows to roll up and roll down with the car off, and it is controlled either by timing or by a remote button on the key fob.
Old Mar 10, 2004 | 11:09 AM
NSXNEXT's Avatar
You might be able to have the windows close based on a timer, but no way you'll get the stock remote fob to control them. You'd have to figure out a way for the module to recognize a signal from the OEM key fob, which I don't believe is possible.
Old Mar 10, 2004 | 11:19 AM
UNCTYPE-S's Avatar
Above n Beyond
so pretty much the only way possible is the get a viper or any other alarm system that carries this module.
Old Mar 10, 2004 | 11:27 AM
NSXNEXT's Avatar
Yeah, you'd really want some control over the windows. Even if you were able to hook this up to the OEM alarm, you wouldn't be able to control them.
Get a Viper with the module built in.
Old Mar 10, 2004 | 12:31 PM
MiK3Y's Avatar
no you dont absolutely have to have an aftermarket alarm system to make it work. what makes the windows roll up is just a constant ground. you dont need any special type of signal from a DEI alarm. i've never tried to hook one up to a factory keyless entry, but to say that its impossible isnt true at all. the keyless entry module must have some wire that you can use in some way to get a constant ground when you lock the doors using the key FOB....such as using a latching relay.
Jul 16, 2017 07:33 AM
iRaw
ILX Photograph Gallery
30
Aug 5, 2016 04:41 PM
xsilverhawkx
Oct 5, 2015 11:00 AM
malvothegreat
Sep 29, 2015 12:38 AM
